Clarifications on “Hard Code” clearing with regular scanner vs. Dealer tools
Old Jun 18, 2023 | 04:43 PM
LukeMiniR53's Avatar
LukeMiniR53
My ‘06 R53 popped code P2096 for long term post-cat O2 sensor lean burn a few months ago. Since then, it comes back every 1-3 drive cycles/every 3-10 miles after I clear it (but I often just leave it).
There are no other lean burn symptoms- not down on power, not running hot, not crazy MPG, etc.
Seeing people say that it can be air, fuel, or spark related, I’ve replaced filters, plugs and wires, and the rear O2 sensor and done my best to rule out any obvious exhaust leaks or intake leaks.
However, it still comes back like clockwork.
In my latest forum deep-dive, I’ve come across folks who say they experienced the same issue, made a fix to a potential cause, and had it come back until they used a dealer tool to reset/clear “adaptations.”
I’ve been using a ~$30 Amazon scan tool that makes the SES light go away and indicates no stored or pending codes. I’ve seen a lot of P2096 threads with people saying their scan tools can’t clear the code, so I figured since mine does I was set. But is this some “lesser” level of clearing that could be resulting in P2096 coming back even if the root cause is resolved? Should I try to find a more advanced tool that can dive deeper to resolve this?
Old Jun 19, 2023 | 04:25 AM
mrbean's Avatar
mrbean
Do yourself a favor and get a hold of a BMW/MINI specific scanner. They are able to read the hex codes from the modules which often provide a clearer picture of the actual problem. This is because there's sometimes several different hex codes associated with one P code. Knowing only the P code doesn't give you the full picture.
I can't speak specifically to your scanner, but more often than not the adaptations get reset when you clear error codes. In your case, it might be a good idea to try a DME reset using the hidden menu.
Old Jun 19, 2023 | 05:38 AM
RockC's Avatar
RockC
That you clear the code and the error stays away for 1 to 3 engine warm up cycles suggests the problem is not with the clearing of the code but that the error condition that triggers the code still exists.
I have no detailed info on trouble shooting a P2096 code but I'd hazard a guess you have more trouble shooting to do. For intake leaks/exhaust leaks you need to be sure there are none. That the code reappears after some engine run time suggests the problem may be temperature related.
sonosam
R60/R61 Stock Problems/Issues
Dec 3, 2018 05:23 PM
mgrant
Apr 19, 2013 09:53 PM
curtw
Feb 23, 2012 02:49 PM
SteveS
Apr 27, 2010 03:22 AM
91Eunos
Jul 19, 2008 08:49 AM
