2007 r52, dsc / p0300
Old May 29, 2023 | 06:16 PM
Bjcook88's Avatar
Bjcook88
Well we purchased our Mini end of last summer with 165,000kms. Over the winter I did some maintenance work on it including the following:
Timing Chain, Chain tensioner, Supercharger Service( Oil, Water-pump, Gaskets) Valve Cover gasket. 17% Super Charger Pulley, Belt Tensioner.
The car ran well for a month. Now that it has warmed up I am getting the above codes. So far changed out the following as they were service items anyway. Spark Plugs, Plug Wires, Spark Coil and just tonight the PCV valve. I have noticed that even with the new PCV valve installed I am still getting enough pressure out of the oil fill cap to inflate a work glove. Is this normal? I am debating taking the car into a local mini shop but want to exhaust all of my options before I do.
update: did a compression test tonight and all of my cylinders are testing within 10% so that puts my mind at ease a little.
thank you
Bjcook88
May 31, 2023 03:55 AM
IceBlueJusta
Apr 19, 2019 06:02 AM
Aaron Owens
May 3, 2018 07:14 PM
Jill Nyahay
May 9, 2017 04:04 AM
toddcann
Mar 22, 2014 10:33 AM
