Trifecta lights and brake light.
Hello all, My 05 R53 threw the trifecta lights. I have replaced all 4 sensors, just did driver rear and passenger front. Now my brake light is illuminated and I still have the trifecta. Before you ask schwaben shows no fault codes, every test passes. So is there something I need to do to reset the systems? My Speedo in my chrono pack doesn’t work now either, but I can see mph on my scanguage. Have checked fuses and don’t see any of them blown either. Please help.
Okay so i dived in deeper with scanning the R53. Live data shows that i dont have anything coming from the rear sensors, which are new Bosch sensors. I ordered a set of OEM Mini rear sensors to see if that is the issue. If i dont see any data from these it almost has to be the wheel bearings right?
So since garbage hasn’t been collected yet, I pulled my old rear abs sensors out and cleaned them. Stuck those in and boom all is good. Still have OEM rear sensors on way just in case.
banyan
Jan 6, 2016 01:25 PM
Speedy400
Sep 23, 2013 03:00 AM
