Oil filter housing cap question
Old Apr 20, 2022 | 06:35 PM
idickers's Avatar
idickers
I've got a 2002 MCS, and the cap for the oil filter housing looks like it's missing the cage in the pic below. This is our second 2002 r53 and I remember the cage on our first car. However, when I look for caps, none have the cage and the cage is not available separately.
Is the cage not needed anymore? The replacement oil filter seems to fit snugly without the cage, I just can't seem to get the threads of the cap to engage with the threads in the body of the filter housing.
Old Apr 21, 2022 | 10:52 AM
nd-photo.nl's Avatar
nd-photo.nl
I bought a new filter housing at the Mini dealer a little while ago and it didnt have the cage
Old Apr 21, 2022 | 05:42 PM
shrevemini's Avatar
shrevemini
Top Answer: 1
Be careful. Do not use new style filter with the cage in them on the old style housing. Can cause damage. The best advice is to either get a new or used up to date version. Not very difficult to swap.
Read below.
https://new.minimania.com/MINI__02_0...roblem___Hints
Old Apr 21, 2022 | 06:55 PM
idickers's Avatar
idickers
Thank you, that helps a lot. It looks like my car has the updated oil filter cap, and I am using a filter with an internal cage (Mahle OX 175D). So maybe I'm just not getting the threads to engage correctly.
Is the oil filter housing different, or just the cap?
Old Apr 21, 2022 | 08:46 PM
shrevemini's Avatar
shrevemini
Top Answer: 1
Both are different.
Old Apr 22, 2022 | 02:51 AM
idickers's Avatar
idickers
Well this is confusing. The PO did some sketchy maintenance, so I'm not sure what is going on here. We have noticed a low oil pressure light which I assumed was due to a failing oil pressure switch, but perhaps there is more to the story.
Can someone tell me what part numbers I should order to install a replacement housing?
Old Apr 22, 2022 | 05:24 AM
shrevemini's Avatar
shrevemini
Top Answer: 1
Here
https://www.pelicanparts.com/More_In...iABEgLI__D_BwE
Grey Thunder
R59 :: Roadster Talk (2012+)
12
Aug 28, 2021 01:09 PM
rob76turbo
Apr 1, 2016 05:07 AM
cw40342
Aug 6, 2014 07:52 PM
Erhan
Sep 7, 2011 11:38 AM
sams05
Jun 12, 2009 07:52 PM
