HELP!!! 1yo issue still can't fix
Old Nov 9, 2021 | 07:00 AM
Beka_2JZ's Avatar
Beka_2JZ
Hello,
I have 2013 US Spec MCS R56 Manual with 90K miles. N18
The car used to run perfectly, almost one year ago in the morning, it suddenly started running rough and revs started to fluctuate at every Cold Start since than. after it gets little warmer(after 2-3 min of idle) the engine runs perfectly.
Did a Lot of Investigation but found NOTHING.
NO CEL. (noticed that once per 3-4 month P0136 comes randomly but doesn't come back any soon after I delete it.)
Replaced MAF, thermostat, Upper O2 sensor, Spark Plugs, Coils, HPFP all of this parts for ZERO result.
checked for compression on cold and on warm engine - 13-14 Bar among all 4 cylinders.
checked for boost/vac Leak - nothing.
removed and cleaned Vanos solenoids.
I also Noticed that car runs worse when its getting colder outside.
Still Cant find anything.
p.s. Once its warm it Car runs Great. Made 180 WHP baseline on 91 with just Wagner IC, NM intake piping and NM intake, no tune.
PLEASE Give me ANY advice, I'm getting frustrated.
I Really love that car and its very painful for me watching it idle like a crap every morning.
will add youtube link of a coldstart soon.
Old Nov 9, 2021 | 07:06 AM
Beka_2JZ's Avatar
Beka_2JZ
Beka_2JZ's Avatar
Beka_2JZ
Old Nov 14, 2021 | 07:33 PM
NeonLed's Avatar
NeonLed
Have you watched fuel pressure on cold start? Should be between 700-800psi (48-55bar) at idle.
Old Nov 14, 2021 | 10:42 PM
Beka_2JZ's Avatar
Beka_2JZ
hey there,
thank you for replying.
Checked Fuel pressure this morning, it was around 1000-1050 PSI - 68-72BAR - do you think im getting TOO MUCH fuel pressure ?
I will recheck fuel pressure later today.
(p.s. I have replaced HPFP before but got ZERO changes. btw I have later model, revised HPFP which is not prone to failing )
Old Mar 4, 2022 | 11:22 PM
Beka_2JZ's Avatar
Beka_2JZ
Still Got Nothing.
Please Help :(
Old Apr 13, 2022 | 06:03 AM
Beka_2JZ's Avatar
Beka_2JZ
*dead Inside*
help
Old Apr 13, 2022 | 06:04 AM
Beka_2JZ's Avatar
Beka_2JZ
Old Apr 13, 2022 | 08:20 AM
NeonLed's Avatar
NeonLed
The short term fuel trim is pinned at -25% which means it’s pulling a lot of fuel out. Is the car ever hard to start? Like cranks and cranks then finally turns over? Could be leaky injector that only effects the car when cold starting it.
Old Apr 13, 2022 | 10:54 PM
Beka_2JZ's Avatar
Beka_2JZ
Hello.
No it starts right away.
I have already done Injector testing about a week ago. they are perfect.
After all this investigation, I Still got no Clue.
Old Oct 20, 2022 | 11:24 PM
actasci's Avatar
actasci
i have a similar issue without any fix on sight. -19% long term fuel trim, hiccups only at cold start and low throttle input and low rpm situations. other than that idle is rock smooth even on cold start. fuel trim eases to about -16% if i drive slowly.
if you fix your problem, please let me know.
Old Oct 26, 2022 | 06:08 PM
GrneEyeDog's Avatar
GrneEyeDog
add me to the list, once temperatures are in 50's, I have jerky, laggy throttle first 1-2 minutes of driving. Once engine warms up - no issues, everything is awesome.
Was shooting parts cannon at the car: got new MAF, OEM coils and spark plugs, new injectors, high and low pressure fuel pumps, fuel filter, cleaned carbon build up, new thermostat, water pump, pulleys, belt, valve cover and timing chain guides. 2011 early build N18 with 138k miles.
Old Oct 26, 2022 | 07:31 PM
actasci's Avatar
actasci
can you also check your fuel trims?
Old Nov 8, 2022 | 12:46 AM
actasci's Avatar
actasci
Small update for those who interested: i picked a cheap noisemaker delete rubber hose from aliexpress and bolted it in. Fuel trims are still the same but there is noticeably less jerkyness now.
Cold start throttle lag is still there but it’s more subtle.
wertslj
Jun 17, 2019 09:09 PM
Squigglesr56
Jun 10, 2019 05:10 AM
wsalopek
Feb 4, 2019 09:33 AM
ken84
Aug 23, 2014 07:24 PM
ACTE
Dec 23, 2013 11:16 AM
