MCS 2011: P0010 code
Old Sep 21, 2021 | 01:03 PM
Dcb22's Avatar
Dcb22
Before I go down the rabbit hole (again), I thought I'd check quickly with you fine folks.
2011 MCS w/ 174K miles. Engine went into limp mode, CEL code P0010.
Should I follow this thread: https://www.northamericanmotoring.co...code-help.html
or is there a better way to move forward?
Any thoughts/comments are always very much appreciated.
Edit: Engine is idling a little rough - some surges up to 1.5K RPM and then back to 750.
Old Sep 30, 2021 | 05:56 AM
Dcb22's Avatar
Dcb22
P0010 is the intake VVT solenoid, which was replaced. Below is a video if anyone ever gets this code and needs assistance:
Just be prepared that some later Minis use a torx bolt instead of a 10mm bolt for the solenoid. The Torx is a 27 or 30 size, but it is very easily stripped. The metal on these solenoid torx bolts (front and back) is like butter and strips with very light torque.
Scooter24
Dec 17, 2022 05:51 PM
adelita
Sep 10, 2020 01:56 PM
raybo1
Feb 26, 2019 07:48 PM
7thmoosefromtheleft
Jan 9, 2019 01:08 PM
Matt_Tate
Oct 22, 2012 12:26 PM
