R56 Multiple Codes
Old Mar 6, 2021 | 05:47 AM
Tyler L's Avatar
Tyler L
R56 Multiple Codes
Hello I recently bought an 2009 Mini Cooper S (R56) I got it with the check engine light on I had been sitting for a while so I thought maybe it was just the spark plugs. Well that wasnt the case.
codes I got are
p303
P300
P302
P304
p173b
I have recently changed the oil and filter and the spark plugs I checked the coil packs one was bad so I had fixed the problem. But unfortunately the problem still persists I'm not sure what else could be wrong other than a bad head gasket or a cracked engine head. It also appears that I'm leaking coolent but I havent located from where yet. Thanks for the help in advance.
Old Mar 6, 2021 | 06:12 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
The 300 codes are cylinder misfires. The 173b code is related to coolant temperature.
Did you replace all the coil packs, or just one? I always recommend replacing all coil packs as a set.
You might need to have the thermostat replaced, too.
Old Mar 6, 2021 | 08:31 AM
cpmetz's Avatar
cpmetz
Just to make sure: you have cleared the codes after changing the coil? To see if they come back?
For coolant leak: there are so many threads around that. Cross over pipe, thermostat itself, ... Mentioning where the puddle is will help.
For the codes the same: timing chain? Carbon buildup?
lai8869
Jul 13, 2019 12:08 AM
chrisd
Jul 13, 2018 05:43 PM
Pramuk
Apr 27, 2018 02:21 PM
vhsnap
Jul 3, 2017 05:26 PM
tylersavage
Jan 29, 2016 08:48 AM
