2009 R56 N14 driving me crazy- misfire 1, 3 and 4
Old Jan 28, 2021 | 01:57 PM
Halophila's Avatar
Halophila
I have a 09 R56 N14 with 98K that is throwing misfire codes for cylinders 1,3, and 4. This is my wife's baby and she is distraught with the idea of not driving this thing. As for me I'm 74 and have lost a lot of my interest in wrenching (I recently changed out the thermostat housing and hoses which resulted in a lot of blue words).
So to begin I checked the plugs and coils which were recently changed. They looked good. I then did a compression test on both a cold and a warm engine. I also performed a wet test on the warm engine. During the wet test, I tightened the adapter in 2 and 3 which then gave me slightly higher readings. I was considering performing a leak-down test but don't know if it's necessary at this point. Any help with diagnosing this misfire I would greatly appreciate it. (I can't believe the wife wants a new mini ??)
Cold engine
Cylinder 1 2 3 4
178 150 178 176
180 160 176 176
Warm engine
170 160 174 165
172 160 168 165
Wet test
162 156 155 175
162 160 165 175
Old Jan 28, 2021 | 05:04 PM
troyegly's Avatar
troyegly
Swap coil pack 1,3 or 4 with #2 and see if it follows. Misfire is the only code or is there some hidden / manufacturer specific codes?
Old Jan 28, 2021 | 06:14 PM
cpmetz's Avatar
cpmetz
Carbon building or timing chain are good candidates.
Timing can probably easier checked than carbon buildup.
Old Jan 29, 2021 | 03:33 AM
Halophila's Avatar
Halophila
I swapped out the coils and still got the same misfire on 1, 3 & 4.
Old Jan 29, 2021 | 03:37 AM
Halophila's Avatar
Halophila
I'm beginning to feel like it's the timing chain. Some rattling noise near the front of the engine. It appears to be a tough job for DIY, and the costs of $1,000+ are high. Do the compression results indicate the engine is worth doing the work? Thanks for your reply.
Old Jan 29, 2021 | 05:56 AM
yeticat99's Avatar
yeticat99
How has the oil consumption been?
I bought a '10 MCS with 124k mi this summer. It was burning oil at about a quart/500 mi. I did a compression test and my numbers were nearly identical to yours (not terrible). I also did a leakdown test and saw a range of 10 to 35%. My Matco leakdown tester shows 40% or lower in the green "Good" range, so I (in hindsight, foolishly) decided to install new valve stem seals and call it good. Oil consumption decreased slightly with new stem seals, but piston #3 had a literal meltdown at 127k mi. It was evident when I tore into the engine that I had bought someone else's disaster (piston #2 didn't match the other 3), so your mileage may vary.
I've since rebuilt the engine and it's back on the road. But, if I were in your shoes and had no intention of turning wrenches on the car, I'd probably sell it and move on. I think a leakdown test would be a good idea before making a decision. Good luck!
James Michael
Oct 17, 2019 11:49 AM
MrWoppit
Dec 9, 2016 04:00 PM
afadeev
Jun 22, 2015 03:38 PM
addamaniac
Mar 16, 2009 05:00 PM
FastBandit
Mar 10, 2006 02:19 AM
