Turbo Oil Leak?
Old Sep 8, 2020 | 06:09 AM
Ineedabiggercar's Avatar
Ineedabiggercar
Turbo Oil Leak?
I have oil on the bottom of my turbo, in the area of my oil return line. The turbo and oil lines had all been replaced under the prior owner at a shop back in January, so I took the car into that shop since they agreed the warranty extended to my ownership.
After inspection, the shop informed me that the oil line (which was new) is not the culprit, but rather it is the used turbo that was installed that is leaking out from where the metal clamp holds it on the hot side. I cannot find many examples of these turbos leaking in the comments.
Would this be a crack inside the turbo, or are there seals in there that might leak? Is it possible I just need a new cartridge? I got a quote for a brand new turbo and oil lines and they came back at $1300 after a labor discount.
Old Sep 8, 2020 | 06:26 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
I would get in there and try to clean it up REALLY good. Then, take another look after driving it around for a little bit. Might have a better idea of where the leak is coming form.
Old Sep 22, 2020 | 08:38 PM
dmath's Avatar
dmath
Any update on this? I'm curious since my car has started using a little oil. It doesn't seem to be burning it (I pulled the plugs) and isn't leaking as far as I can tell so I'm starting to think about the turbo.
Old Sep 23, 2020 | 02:36 AM
Ineedabiggercar
Sorry, no update yet. My time have been taken up by two other cars, but I might try to fit this in soon. I will let you know!
JCC9
Jan 29, 2018 02:19 PM
CountryS
Aug 9, 2016 02:59 PM
mzacherle
Jan 24, 2014 07:33 AM
texasmontego
Oct 30, 2012 10:05 AM
Maurtis
Sep 14, 2010 07:33 AM
