2015 r60 n18 multiple dtc errors
Old Aug 8, 2020 | 09:34 AM
ilookmarvlus's Avatar
ilookmarvlus
I have 3 MINIs and my newest is a 2015 R60 with just under 60K miles. They're all well cared for in the last 3K miles all new filters, new iridium plugs, oil change, etc. I recently had the HPFP changed on our R57 and now I am experience a similar behaviour on the R60. It starts out good but after a bit the idle is very unstable and yesterday it started showing the yellow CEL engine warning although I felt no stumbling.
Carly shows the following DTC codes oldest first:
2BC0 MIXTURE TOO LEAN (NOT SERIOUS)
2775 AIR MASS TOO LOW (NOT SERIOUS)
2EEF CYL 4 MISFIRE
2EEB CYL 3 MISFIRE
2EE5 CYL 1 MISFIRE
2F00 CYL 2 MISFIRE RECOGNISED
2F02 CYL 4 MISFIRE RECOGNISED
2F01 CYL 3 MISFIRE RECOGNISED
2EFF CYL 1 MISFIRE RECOGNISED
2EFE MISFIRING SEVERAL CYLS RECOGNISED
I am trapping no issues with the HPFP or injectors and it seems very doubtful that every coil pack would tank at the exact same time. I'm wondering if I got a bad tank of gas perhaps with moisture contamination?
Any recommendations to troubleshoot this more accurately?
Thanks in advance.
Old Sep 16, 2025 | 12:38 PM
Foxgoku's Avatar
Foxgoku
Did you ever get any solution to this? I recently started getting something similar after coming back from holiday.
Old Sep 16, 2025 | 12:50 PM
Maybe, maybe not's Avatar
Maybe, maybe not
Community Builder
Community Influencer
If not identical to original post, post all of your fault codes and add car information.
Old Sep 21, 2025 | 04:36 PM
MCSHATCH's Avatar
MCSHATCH
I'd look for an air leak since you have the MAF and a O2 code indicating lean and a lean condition can also cause a misfire.
Kcblackwell07
Jan 22, 2018 09:56 AM
spatulatr0n
R55 :: Clubman Talk (2008+)
Mar 17, 2017 01:21 PM
daonlyillwiz
Jul 9, 2016 10:48 AM
HorizonBLueN18
Jan 5, 2016 02:47 AM
ms.mini
Mar 31, 2014 06:36 AM
