Front caliper bolt replacement
Old May 22, 2020 | 09:05 PM
dmath's Avatar
dmath
Today I removed the front calipers on my R60 Countryman so that I can paint them. Unfortunately one of the bolts that mounts the caliper to the caliper carrier broke. It's M8 22mm 10.9 grade. I got lucky and was able to remove the stub with a little effort. With the holiday weekend, and shipping time, it will be more than a week before I can get a genuine replacement from ECS. Locally, I can find M8 10.9 bolts in 20mm and 25mm lengths. Does anyone have experience (or opinions) on using slightly longer or shorter bolts in this application? Advice appreciated.
Old May 23, 2020 | 04:22 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
Was it item #3 in this diagram?
https://www.realoem.com/bmw/enUS/sho...diagId=34_1523
If so, that’s one of the slider bolts, and is very special. You could replace it with a regular bolt, but the caliper will not move as designed, and could cause your brakes to drag. This could lead to further problems.
I would chalk this up to an expensive learning experience, and just wait for the new bolt to arrive from ECS.
Old May 23, 2020 | 05:28 AM
dmath's Avatar
dmath
Thanks for the reply. It was #3 but just the M8 bolt that goes into the slider. The slider part seems fine and the M8 bolt seems like a standard 10.9 grade hex head bolt. Quite a bit of the broken stud was exposed so I was able to remove it without too much trouble. At the moment, I don't see why replacing the bolt part would be a problem. I'm not saying you're wrong, just want to understand before proceeding.
Here's a photo of what broke -- this is one of the others, not the broken one.
Old May 23, 2020 | 05:41 AM
cooper48's Avatar
cooper48
Check Ace Hardware. They have an amazing inventory of screws, bolts, washers, etc. - even chrome ones. I use them all the time for hard to find fasteners.
Old May 23, 2020 | 05:44 AM
dmath's Avatar
dmath
Thanks. I checked Ace. They have 20mm and 25mm but not 22mm.
colinmini's Avatar
colinmini
As a mechanical engineer, making sure that you use the same grade bolt is the key. Try to make the same length, but longer here just means threads going into the slider more, shouldn’t interfere. I personally would use Lowe’s, find the matching grade bolt(Head should have markings to determine) and use a similar thread locking compound when re-installing. You can also order an oem bolt to replace during next opportunity, if you have any concerns.
Old May 23, 2020 | 07:50 AM
dmath's Avatar
dmath
I agree on using the same grade - I never substitute different grade. I measured the "recess" in the slider. It's 12.19mm. The connecting point on the caliper is 13.4mm. So the 25mm bolt will not bottom out. I'll use that for now and order an OEM replacement the next time I order from ECS. And I'll use Loctite Blue as specified.
farside847
Tires, Wheels, & Brakes
Mar 24, 2019 08:26 PM
edinamini
Jan 18, 2014 07:07 AM
Noir2005
Jun 22, 2012 08:17 AM
gohandbz8
Jul 8, 2007 12:41 AM
