R53 with sport suspension - front sway bar diameter?
2004 R53. Will be dropping the front subframe in order to replace a leaking rear main seal. Will take this opportunity to replace the sway bar bushings. This is a 2004 R53 with sport suspension. Is the diameter 22.5 or 24 mm? Also, is it advisable to replace the steering rack bushings and if so, any difficulties likely to be encountered?
Yes it should be 24mm
https://www.waymotorworks.com/powerf...-bushings.html
and make sure you're doing the control arm bushings
https://www.waymotorworks.com/powerf...shing-kit.html
We also always do the rack bushing when we have the subframe out as it takes 5min
https://www.waymotorworks.com/powerf...k-bushing.html
If you want to go big it's the ideal time while the trans is out to do a Quaife LSD as that will get all your power to the ground and save you a bunch of labor later
https://www.waymotorworks.com/quaife...ferential.html
JAB 67
12
Jan 10, 2019 08:43 AM
astroBlackMetallic_Mini
May 13, 2013 05:18 AM
Suspension so, what size is the front swaybar bushings?
Suspension
May 12, 2013 05:11 PM
alx873
Suspension
17
Apr 11, 2010 05:59 PM
