R53: Valve Spring Compressor
Old Jan 17, 2020 | 02:38 PM
jjcsnlynn's Avatar
jjcsnlynn
I removed the valves with one if my old type of valve spring compressors but it was a but hairy.
For my R56 I bought one that mounts to the top and you compress the lever but it won’t mount to the R53 head.
Any recommendations on a newer style valve spring compressor for the R53 head? Only R56 on was like $35.
Old Jan 17, 2020 | 04:28 PM
OCR's Avatar
OCR
I used an old fashioned "C" clamp type on mine. Just... the clamp worked well on the intake side valves. The exhaust, I needed more tool arm space. I used a nut about the diameter of the retainer for more open space, then used a magnet to pull the locks out.
Putting the exhaust back together will be another matter. A modern tool will work definitely better for the exhaust.
An arm with about a one inch "dip" in it would work.
Mike
ZlotyR50
Mar 24, 2020 07:27 PM
outlawspeeder
Aug 2, 2019 11:36 AM
wojtek@pagacz.ca
14
May 23, 2018 02:32 PM
rutteger
Dec 1, 2014 03:55 AM
bkjnf
Aug 4, 2013 07:52 AM
