N18 Rattle, Timing Chain? HPFP?
Old Dec 21, 2019 | 02:47 PM
minimesd's Avatar
minimesd
Hi All just picked up a 2013 JCW with the N18 motor with 98k . Would you mind taking a listen and giving me your option on this sound.
I removed the valve cover and the upper timing chain guide looks fine.
Honestly I am not sure what a normal R56 should sound like.
M
Old Dec 21, 2019 | 05:07 PM
AZdsrt's Avatar
AZdsrt
Hard to say from the video. Our 2012 MCS has always made a sewing machine sound.
Old Dec 21, 2019 | 05:26 PM
MrGrumpy's Avatar
MrGrumpy
It’s always hard to tell with video, but it sounds pretty normal to me. With the direct injection you can hear the injectors and the HPFP making noise... it’s a noisy diesel/sewing machine sound......sort of..... but make sure your oil is fresh and topped up and you should be good to go!
Old Dec 22, 2019 | 12:48 AM
Kupona's Avatar
Kupona
I used to get weird rattles from various things. Hold with your hand the air pipe coming from front bumper to air box, might eliminate some vibrational sounds. If you genuinely think it sounds off, buy a car stethoscope and investigate. Sounds normal-ish to me but every mini engine sounds a little different
Old Dec 22, 2019 | 05:37 PM
minimesd's Avatar
minimesd
After driving it around a bit more and sticking my ear close to the HPFP, I think the majority of the noise is from the HPFP. It sounds like a ball of marbles. Is that normal?
Car drives fine. No check engine light.
M
Old Dec 22, 2019 | 07:49 PM
Kupona's Avatar
Kupona
One way to test HPFP is with a scan tool that can read fuel pressure (low and high). I was told with car off, press ignition without foot on brake and scan with tool and your HPFP should be outputting 65-75 psi. During normal operation my HPFP sits between 1180-1220 psi with peaks to 2200 under heavy boost driving. If you are in California around Orange County i'll come scan your car with my scantool no charge to help you out.
Old Dec 24, 2019 | 05:05 PM
Lancaster's Avatar
Lancaster
It sounds a little louder than my R56 N12 engine. Do you have a really light oil in it? I think mine quieted down a bit on 5-40. Does not sound like chain rattle to me - wouldn’t know about the HPVD
Edit - That’s HPFP... funny. Thankfully would not know about HPV either....
Old Dec 26, 2019 | 10:11 AM
KeyPlayaJim's Avatar
KeyPlayaJim
If you have a manual transmission (not sure if this works with an automatic), try cruising on a quiet road surface at a low speed -- 15-25 MPH -- then lift your foot off the gas pedal. If the noise immediately stops, it's probably just the fuel injectors (they shut off under those conditions to save fuel). It's very noticeable in my car.
Old Dec 26, 2019 | 12:08 PM
mellocooper's Avatar
mellocooper
Anyone ever replace timing chains just for precaution? My 2013 MCS has been rock solid reliable at over 90k (bought at only 8500) and I’d like to keep it as long as I can, at least another 25k.
Old Dec 26, 2019 | 01:10 PM
cooper48's Avatar
cooper48
I have an R53 and I'm not sure of the similarities, if any, between your drive belt tensioner and mine but just a word of caution. I had a similar noise that I thought was a loose timing chain. It turned out to be a rattle caused by a missing bushing in the drive belt tensioner damper that caused the damper to vibrate against one of the attachment bolts. A $12 part (new damper) and 30 minutes labor and the noise is gone. It may be worth checking on your MINI.
Old Dec 26, 2019 | 01:22 PM
MrGrumpy's Avatar
MrGrumpy
Yeah the tensioner and also the water pump pulley and friction wheel can rattle if they are getting tired. The HPFP is pretty noisy, I think it’s just the HPFP and injectors you are hearing. For oil I run Liquid Moly 5-40 and it quiets it down a little. These are noisy little engines.
Old Dec 27, 2019 | 09:03 AM
minimesd's Avatar
minimesd
Thanks everyone for your suggestions. I have not had a chance to tear into the engine yet.
Old Dec 30, 2019 | 01:31 PM
Jimmy-R56s's Avatar
Jimmy-R56s
Would this rattle in relation to revs? I’m getting a rattle that sounds similar to a heat shield but is related to revs, I’m starting to think it might be waste gate related
minimesd
Dec 20, 2019 08:40 AM
IsaacinPhilly
Jul 25, 2018 04:20 AM
NathanMckee
Dec 26, 2015 07:04 PM
MINI_42
Factory JCW Talk (2009+)
Oct 7, 2013 01:06 PM
micromini234
Jul 17, 2013 05:57 PM
