P173B Code
Old Dec 10, 2019 | 03:56 PM
PAMedic13's Avatar
PAMedic13
P173B Code
I just did the turbo oil line fix. After putting it back together, I refilled the coolant reservoir but I'm getting Coolant temperature sensor error. Will this go away after running and replacing what coolant was lost during the repair? Any advise would be appreciated.
Old Dec 11, 2019 | 06:08 AM
MiniToBe's Avatar
MiniToBe
can you run the live data to see what temps the ECU is actually seeing? also, did you bleed the system?
Old Dec 11, 2019 | 06:56 AM
PAMedic13's Avatar
PAMedic13
P173b
I believe my diagnostic reader does. It will show live data while running. I did not bleed the system so I’ll look to find out how and give that a try. Thanks for the info.
PinkMiso
Nov 27, 2018 02:51 PM
michaewlewis
Sep 9, 2018 09:59 PM
Andrew Riley
Mar 21, 2017 07:03 PM
mini4tide
Nov 14, 2012 05:45 AM
Tora-blitz
May 4, 2012 03:43 PM
