class action?
Old Nov 28, 2019 | 03:04 PM
Allen Butler's Avatar
Allen Butler
class action?
i have a 2010 cooper s with less than 70,000 miles on it timing chain broke causing engine failure i know there was a class action done a while back but for some reason 2010s where not included. i am considering trying to get another one going since i know there are a lot of folks with this issue and i dont see why the consumer should pay $8,000 for a new engine when bmw knew the part was defective and never recalled it. any thoughts would be appreciated
Old Dec 3, 2019 | 06:11 AM
MiniToBe's Avatar
MiniToBe
The timing chain broke because the vacuum pump seized. And it seized because of oil starvation. Is this the case?
not sure if they will cover it under this scenario but you can always call them for options.
you might be able to save the engine. I had a 2011 N18 engine with a broken chain. I replaced the vacuum pump and timing chain. Luckily, the valves were fine and the car ran fine afterwards.
your issue is finding a mechanic who's willing to do these repairs with a fair price. Even if you had to pull the head, it shouldn't be that crazy expensive.
where are you located?
Old Dec 3, 2019 | 06:47 AM
mini-is-for-me's Avatar
mini-is-for-me
What is the vacuum pump? The power brake vacuum pump?
Old Dec 3, 2019 | 06:50 AM
MiniToBe's Avatar
MiniToBe
Yes. On the non s, it is only for the brake system/clutch. On the S it is also for the turbo. These tend to seize if oil starved.
Old Dec 3, 2019 | 06:03 PM
mini-is-for-me
Hmm, where is this located on the S? Is there a line on the N18 intake that goes to this? What does this vacuum pump do for the turbo?
HERE?
https://new.minimania.com/part/G2NME...2-R55-r61-2011
Old Dec 3, 2019 | 08:15 PM
MiniToBe's Avatar
MiniToBe
Not the intake. There are two lines coming out of the vacuum pump. A hard line goes to the brake booster and another soft hose goes to a valve. The valve is connected to a canister and to the diverter valve on the turbo.
chrisd
Nov 17, 2018 06:47 PM
13ms13
Dec 11, 2017 04:36 AM
jrw429
Apr 10, 2017 10:21 PM
Redpepper31
Oct 20, 2016 08:24 AM
damiencain
R55 :: Clubman Talk (2008+)
Jun 3, 2014 05:12 PM
