Coolant in The Expansion Tank................
Old Nov 9, 2019 | 06:01 PM
dube53's Avatar
dube53
What should be the level of coolant in the expansion tank when the engine is cold from overnight?
I run my A/C all year around and I often have a small puddle of water under the car. This doesn't smell or "taste" like coolant. At this time of the year, this seems strange.
I just replace a bad upstream O2 sensor but this has nothing to do. What should be checked?
Old Nov 9, 2019 | 06:44 PM
mini-is-for-me's Avatar
mini-is-for-me
That's condensation from the cooling fins of the A/C Evaporator Core. Turn your A/C off and it will stop. You are wasting energy (and gas mileage) running your A/C and then heating your car to compensate for the A/C.
Old Nov 9, 2019 | 07:40 PM
dube53's Avatar
dube53
With respect, I can tell you that is not true. Running A/C all year around remove moisture particularly in winter and it keeps the refrigerant and oil lubricating the compressor for better and extended reliability. You can use the heater and A/C in same time at a setting temperature for improved air quality.
Old Nov 9, 2019 | 08:13 PM
Fly'n Brick's Avatar
Fly'n Brick
Regardless, the clear water dripping on the pavement after shut down IS condensation. There's even a condensation removal hose coming off the coils on your household cooler. It's the nature of the beast. Can't speak for the expansion tank as not being familiar with the later models. My finger tells me the coolant lever prior to building a fire under it.
Old Nov 10, 2019 | 12:58 AM
Scudder44's Avatar
Scudder44
Coolant level is indicated on the side of the expansion tank, low and high so have it in the middle when cold.
The condensate from the AC should drain onto the floor corresponding to the middle of the dash. If you look under the car when parked after a journey you will see if dripping.
Old Nov 10, 2019 | 10:12 AM
mini-is-for-me
You can tell me what is not true? --- that it uses more power and decreased gas mileage? Tons of studies that prove that. Also, it is basic thermodynamics and it should be obvious. A/C on, enables the clutch, Clutch engages compressor, compressor causes increases demand on engine, engine works harder, gas mileage is reduced. Running the A/C typically will cost you 1-2 mpg. That is "wasted mileage and energy" when you don't really need it.
Here are some articles that prove that I'm right.
https://www.plymouthrock.com/blog/do...y-gas-mileage/
https://www.consumerreports.org/fuel...or-ac-running/
Q. Does a car use more gasoline when you drive with the windows rolled down or the air conditioning turned on?
A. This is a question that has lost plenty of people a bet. “We’ve tested this at various temperatures with multiple vehicles,” says Jake Fisher, CR’s director of auto testing. “We found that on an 85-degree day, running the A/C can reduce fuel economy by 1 to 4 mpg, depending on the car
Driving with the windows down on a hot day is equivalent to heating your car and running the A/C.
Old Nov 10, 2019 | 10:14 AM
mini-is-for-me
Correct.
victor101
Apr 22, 2016 09:13 PM
R56typeS
Jun 8, 2015 06:05 AM
moarsecode
12
Jun 5, 2015 06:14 AM
Nick Danger
Jun 24, 2011 09:25 AM
kenchan
Apr 24, 2004 04:12 PM
