Help need mini 2007
Old Oct 9, 2019 | 07:47 AM
Rustymiller02's Avatar
Rustymiller02
Help need mini 2007
Rebuilt my 2007 R56 mini cooper engine. The mecanics who did it didn’t really know how to work a mini. So because of all this, it took near 2 years to rebuilt the engine and the guy putu it on and out many time. But now its ok, and the car have been sent to another garage because the engine dont want to accelerate on start. We change everything, fuel pump, intake, gaz pedal, computer !! The dam thing is starting with difficulty and stay on idle without any reaction when we press the gaz pedal. Any ideas of cant be wrong? Its surelly not a mecanical issue! But electrical one. I am just about to tear the car apart and sold the engine only, totally depress
Old Oct 9, 2019 | 12:36 PM
oldbrokenwind's Avatar
oldbrokenwind
Modifications?
CEL?
Codes?
N14 or N12?
Does the engine have an MAF sensor?
Old Oct 9, 2019 | 12:57 PM
Rustymiller02
Modifications? None, rebuilt like origin
CEL? What is that?
Codes? None so far
N14 or N12? N14
Does the engine have an MAF sensor? YES, have been changed
Old Oct 9, 2019 | 01:35 PM
oldbrokenwind
CEL = Check Engine Light.
With no CEL and no codes, chances are the electrical system is OK. Maybe ensure the ground wire in the front center of the valve cover is connected and secure.
After rebuild, it's common for the timing to slip a little bit --- chain wasn't tightened correctly, or it was kinked. Pretty easy to recheck it. Take a look at step #28 in this newTIS procedure, https://www.newtis.info/tisv2/a/en/r...aft/1VnY7d2Xnh just gotta pull the valve cover and use the timing special tools.
After two years of just sitting, you might have a partially clogged fuel filter, especially on an '07 --- it's already pretty old.
Old Oct 10, 2019 | 04:31 AM
mini-is-for-me's Avatar
mini-is-for-me
Originally Posted by oldbrokenwind
"... an '07 --- it's already pretty old."
It really is an '09 because it took 2 yrs to rebuild the motor.
Old Oct 10, 2019 | 06:10 AM
MiniToBe's Avatar
MiniToBe
here are few things I would do:
1- remove the valve cover and check the timing, AGAIN.
2- verify the gas paddle is connected.
3- verify the throttle body is connected.
4- use live data to see reaction to gas paddle.
you mentioned you replaced the computer. which computer was that?
where are you located?
Roger Winright
Dec 18, 2017 07:12 AM
minigirl78
Oct 5, 2017 02:12 PM
Laura Redd Casler
Nov 12, 2016 07:49 AM
johnnosek
May 9, 2007 11:29 AM
Larry Clemens
Aug 2, 2006 12:06 PM
