Transmission questions
Old May 25, 2019 | 10:05 AM
SlyCooper06's Avatar
SlyCooper06
Hey y'all. I have a R53 Mini Cooper S with a 6 speed manual. I've owned it for approximately 2 years. I have a question regarding normal transmission operation. I recently replaced both of the CV axles and I've noticed that when my car is parked, engine off, and in gear my wheels have a bit more "play" or "slack" when rotating them in the direction they're intended to go. My question is, how much "slack" should my transmission have? Is the gearing normally tight on these cars or do they have some "wiggle room"? Thank you in advance for any comments.
Old May 26, 2019 | 08:59 AM
ItsmeWayne's Avatar
ItsmeWayne
They do have "wiggle room", but if it is excessive, it may be due to worn final drive gears. I don't think it is a problem. the higher the miles the more play, you can expect.
Old May 27, 2019 | 07:13 AM
SlyCooper06
It has 127k. It's noticable enough that when I'm letting off the throttle in gear, the car seems to rock backwards and forwards. However, it shifts fine, there's no grinding noises going through the gears, but it does sometimes seem to hesitate with acceleration. It almost seems to surge under a load
Jordan Smythe
Sep 9, 2017 08:36 PM
hippymini
May 25, 2011 02:36 PM
Black Boots
Jan 2, 2010 12:51 PM
Blazermaniac
Sep 24, 2007 01:17 PM
soundstruck
30
Feb 2, 2007 05:22 PM
