2010 Mini Cooper S vacuum pump leaking oil. How critical is this?
Old Mar 21, 2019 | 03:00 PM
Phasma Felis's Avatar
Phasma Felis
I took my 2010 Mini Cooper S into the dealership for a Check Engine light; it needs a new timing chain (which I've told them to go ahead with), and the vacuum pump is leaking oil. The dealership says that the pump needs to be replaced (for $842) in the next couple of months or the engine could seize up.
I read the FAQ and saw that this is a known issue. My question is, will making sure to keep the oil topped up keep the danger at bay? Or do I really need to get the thing replaced ASAP?
Thanks!
Old Mar 21, 2019 | 03:34 PM
MCS02's Avatar
MCS02
MINI Alliance Ambassador
I would replace it ASAP. A lot of MINIs have meet their demise due to the vacuum pump.
Old Mar 21, 2019 | 06:04 PM
AZdsrt's Avatar
AZdsrt
Yep, replace it. If it goes... kaboom
Old Mar 22, 2019 | 07:38 AM
08miniS08's Avatar
08miniS08
It needs to be replaced asap, but $842 is ridiculous. The part is very easy to swap out and isn't all that expensive. I think I bought the pierburg one for about $120 and did it myself.
Old Mar 22, 2019 | 07:46 AM
Yupetc's Avatar
Yupetc
There is a o-ring gasket mating the vacuum pump to the head. Why not try to replace that o-ring gasket first? It's only 3 bucks, link below:
https://www.ecstuning.com/b-elring-p...06d145117~elr/
If this doesn't stop the leak, then go for the pump replacement, if you end up buying the pump, just note that it will come with the gasket. link below:
https://www.ecstuning.com/b-pierburg...667556919~pie/
As far as doing what the dealership tells you, I only trust their diagnosis, never their quote on actual repair. If you are here in Houston, TX, I can easily help you with the work, it's really easy to do. Good luck.
Tylerlanger1
Jul 5, 2019 04:30 PM
idickers
Feb 6, 2016 08:54 AM
michmike
Dec 10, 2014 03:00 AM
JubalH
Burning River MINI
18
Jan 24, 2009 07:17 AM
kmickey
Jun 10, 2005 07:15 PM
