radiator smoke
Old Feb 2, 2019 | 09:49 PM
yyj3869's Avatar
yyj3869
radiator smoke
It's so raining in Socal now. I noticed that there was white steam smoke coming out of hood scoop. I thought since it's raining so bad, water comes into the engine bay and causes steam..
I checked the coolant temperature with obd live bluetooth scanner and it looked fine. it was around 95ish. while idling, i turned heater on and it started smoke from radiator but coolant temperature was normal though.. I don't know what's going on. I recorded video of smoke from radiator..
Old Feb 3, 2019 | 06:13 AM
Tgriffithjr's Avatar
Tgriffithjr
Heck your coolant levels. Does it stop after a while when it warms up? If it never stops I would look for a leak especially if you see fluctuations in your temp. Radiators get hot so it may just be moisture that accumulated overnight from humidity in the air or the warm radiator condensing humidity out of the air.
Old Feb 3, 2019 | 06:32 AM
NC TRACKRAT's Avatar
NC TRACKRAT
Veteran: Navy
If it smells like coolant, then it's coolant. If it doesn't, it's not.
spyked
Jan 24, 2017 01:50 PM
darigaaz12
May 12, 2011 02:38 PM
MInI___Gz
Electrical
27
May 24, 2009 08:10 AM
AK430
Jan 6, 2003 08:54 PM
AK430
Jan 3, 2003 08:34 PM
