Hpfp reading low when braking???
Less than 2k after burnt exhaust valve repair. Im getting the knock and super knock codes with reduced engine power light in but no Obdii cel. I cleared the mini specific codes with my Schwaben scan tool. With scan tool plugged in I pulled up fuel pressure values. The tool has an option to show “actual value” and “set point value.” I kept on eye on both values while driving and noticed actual is very close to set point in every driving condition except deceleration/braking. When I come off freeway and brake, the actual value dips significantly below the set point, but only briefly. Strangely, this did not trigger anything. No lights. The hpfp actual and set point values are in line when superknock and knock codes were triggered once right after start up at idle and two other times at 65mph going up a long hill. So I’m not so sure it’s my hpfp. I’ve been through the super knock threads and it appears there isn’t a clear cut solution. My head was just repaired so no carbon buildup. I had injectors cleaned and tested. I didn’t replace chain because it was within spec and no rattling. I know it could be anything but I just wanted to know about the fuel pressure dipping to about 50% of set point value only when deceleration/braking.
Thanks for your reply
Good idea. Not sure how the in tank pump is positioned. Also not sure how it sucks fuel out of the tank. I think the tank does have two sections... Uhhh... You might be on to something though. If your theory is right then a full tank of gas should cure the problem. I have a steep driveway and can check pressure with it facing downhill.
roach_juts
R55 :: Clubman Talk (2008+)
Jul 29, 2022 10:19 AM
OutMotoring
Feb 21, 2017 09:05 AM
isthar
Mar 23, 2012 11:38 AM
jaxsngrl
Tires, Wheels, & Brakes
Nov 23, 2010 10:53 PM
mataku
15
Dec 6, 2004 09:34 PM
