Trouble starting when cold
Old 11-11-2018, 03:16 PM
cavaliers60's Avatar
cavaliers60
cavaliers60 is offline
I’ve been having some instances where my car has a lot of trouble starting in the mornings. Seems to be really apparent when it’s cold outside. This morning, it almost didn’t start at all. Almost like the cranking power of the battery is bad, but it’s a brand new battery from this summer! Also a new alternator. Curious if there is anything specially weird with these coopers and winter temps?
Old 11-14-2018, 04:28 AM
Tgriffithjr's Avatar
Tgriffithjr
Tgriffithjr is offline
Heck all your electrical connections to battery and alternator and body grounds. How cold is it? Cold weather stresses batteries and if your connections are not solid it will be more sluggish than what you might see in warmer weather.
Old 11-14-2018, 06:40 AM
Fly'n Brick's Avatar
Fly'n Brick
Fly'n Brick is offline
Mr T should also have asked how old the battery is. 5 to 6 years is the onset of it's end of life and cold WX does add to the poor old thing's stress.
Old 11-14-2018, 07:12 AM
Racingguy04's Avatar
Racingguy04
Racingguy04 is offline
Does it crank and crank without starting? or is it hesitant to crank? with a battery that was new this summer, your battery is most likely not the cause (unless you were unlucky and got a bad one). Mine sometimes takes a few cranks to get going on cold mornings. I've found that if I give the fuel pump time to prime, it starts a little faster. So you might try letting it sit for like 5-10 seconds with the key turned on, but not cranking and see if that helps it start faster.
You also might have a look at your spark plugs, spark plug wires, and coil, especially terminal 3 if you have the oem coil as it's prone to corroding.
Old 11-14-2018, 07:16 AM
megaDan's Avatar
megaDan
megaDan is online now
I had this exact same issue (albeit in another german car) last winter. New battery didn't solve the issue. It turned out my starter was dying. All the symptoms were weak cranking which made me think battery. If the car is cranking, I wouldn't suspect wiring. Either battery or starter. If the battery is good, go after the starter.
MCSmoonshine
11-02-2012 03:39 AM
UKCountryman
R60 :: Countryman Talk (2010-2015)
04-18-2012 08:02 AM
orcadog
04-21-2010 09:25 PM
sdv515
05-16-2006 07:42 PM
Kimini1
09-11-2002 06:12 PM
Quick Reply: Trouble starting when cold
