6-sp transmission oil - question
Old Oct 5, 2018 | 10:45 AM
JAB 67's Avatar
JAB 67
My 2004 MCS has 156K on it. Many years ago I changed to Redline MTL. No complaints. Recently I had to replace both axles for leaking CV boots, and the passenger side now leaks at the seal. How does one remove the old seal? Any precautions in installing the new one? While researching this issue, I found that one commentator on this forum has written that every time you remove an axle from the transmission you must change the oil. True? If so, why? I simply planned to have some MTL on hand to top-up what is already there. Thanks.
Old Oct 5, 2018 | 06:26 PM
ItsmeWayne's Avatar
ItsmeWayne
If you use aftermarket axles, the seal surface can be different. It is always good to change seals.
Old Oct 5, 2018 | 06:38 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
We just use a standard seal tool, but not common for them to fail. So I'd be concerned that your new axle isn't right or something.
Seals if you need
https://www.waymotorworks.com/axle-s...-cooper-s.html
Old Oct 8, 2018 | 11:24 AM
JAB 67's Avatar
JAB 67
Way: What do you mean by 'standard seal tool?' And any special precautions when installing the new one?
Old Oct 9, 2018 | 06:38 PM
WayMotorWorks
Vendor
Just a generic seal driver kit from snap on or matco they have several size rings you can tap it in.
Dennis Bratland
Sep 12, 2016 04:44 PM
sarom058
Jul 8, 2016 03:01 PM
hippymini
May 25, 2011 02:36 PM
JAB 67
Apr 23, 2010 03:16 PM
