P1476 with two P0326 codes?
Old Jul 16, 2018 | 04:08 AM
cavaliers60's Avatar
cavaliers60
I was on the highway yesterday when my check engine light came on once again. This time, it threw different codes. One P1476 (EVAP Emission Control LDP Circuit Malfunction/Insufficient Vacuum) and two P0326 codes (Knock Sensor Circuit Malfunction)
i did notice my engine engine is not running very smooth at idle, but seems to drive fine minus some weird hesitation when shifting at times. That has only recently started, so may be due to this EVAP issue? Also had one instance where my car didn’t want to start up easily. But auto store says that I would need to replace the LDP pump. I just want to double check and make sure this is indeed the issue before buying a $130 part.
Old Jul 16, 2018 | 07:42 PM
cavaliers60
Bump
Old Jul 17, 2018 | 04:47 AM
Whine not Walnuts's Avatar
Whine not Walnuts
The P1476 could be a vacuum circuit tube either being loose or bent/crimped. Have you tested the knock sensor?
Old Jul 17, 2018 | 03:16 PM
cavaliers60
not yet. I haven’t had a chance to really look into it. I was curious if anyone else had a similar issue and what resolved it. Car seems to drive fine. No noticeable knocks other than you can hear some hesitation in the motor while idling. Isles like it would if a vacuum hose isn’t connected, so I’m betting it’s a loose hose. I just need to make time to look over everything.
Only major issue im having is sometimes the car struggles to start, but once it does, it seems to run fine. Just a minor annoyance.
Old Jul 17, 2018 | 06:51 PM
cooper48's Avatar
cooper48
Codes defined
P1476 = Leakage diagnostic pump clamped tube
P0326 = Knock sensor Bank 1
robc
Dec 14, 2011 09:51 AM
katcokrg
Jan 3, 2011 07:13 PM
Wagnbat
DC Metro MINIs (Archive)
Oct 12, 2008 07:21 AM
Pipper
Apr 25, 2007 11:30 AM
ATSTodd
Mar 7, 2006 05:04 AM
