A/C expectations
Old Jul 14, 2018 | 08:04 PM
BBside's Avatar
BBside
A/C expectations
On that subject if I could ask, how well does a properly running ac system cool an r53. I just acquired one with 150kmiles. No records. The blower motor is mediocre most the force comes from the side vents not central and Id say the coolness of the air is maybe a 6 out of ten on a hot day. Id like to think a BMW product should do a better job but this is a first gen design so I was skeptical at putting the money into refreshing the system. Just like some input if you guys dont mind. Thanks
Old Jul 15, 2018 | 05:04 AM
Whine not Walnuts's Avatar
Whine not Walnuts
The MINI is not an air cooled Porsche that means the AC is very good. If you are not getting good circulation then either the fan motor is shot or the duct actuators are on the fritz. Have you had the system checked? Or you able to do your own wrench turning?
Old Jul 15, 2018 | 06:07 AM
buzzsaw's Avatar
buzzsaw
After 12 years of ownership, I noticed that our R53's yet to need service a/c wasn't as cold as I would like. After reading many a thread on a diy recharge and the ensuing dilemmas, I took it down to our trusted indie shop and they evacuated the system and recharged it. It only took a half a pound of coolant. They thought that was outstanding after 12 years. Me too. Word to the wise, have the a/c sysem serviced by experienced professionals. It's worth the money.
Old Jul 15, 2018 | 11:04 AM
BBside's Avatar
BBside
Have not had it looked at... still sorting out an oil leak and an inoperative hatch switch.
Old Jul 15, 2018 | 12:19 PM
A383Wing's Avatar
A383Wing
Check to see if your car has the cabin air filter under the passenger side in the heater box......I bought an '04 R53 MCS 2 years ago, and an '06 R52 MCS JCW a couple weeks ago and I pulled what looked like the OE filters from each of the housings.....I don't think that they were ever changed since new
Old Jul 15, 2018 | 01:05 PM
Fastlane's Avatar
Fastlane
Do you have the auto climate control? If so, I’ve found that when running it on “auto” rather than manual with the vent control specifically set to the front vents, it blows a fair amount of air through the big upper dash vent and other places. Maybe try setting it manually to see if it works more to your liking. If the air isn’t getting cool enough, then that’s another story....you need to have it serviced in that case.
Old Jul 15, 2018 | 05:11 PM
ItsmeWayne's Avatar
ItsmeWayne
When sticking a thermometer in the center vent, you should be getting down to 38 to 45F.
If not, the charge needs to be adjusted and possibly so other repairs may be required.
Old Jul 15, 2018 | 05:26 PM
Whine not Walnuts
Thinking that the average Delta T of an auto ac is around 40 degrees.
Unless you had an air cooled Porsche and then you learned to just put a bag of ice on your lap.
Old Jul 17, 2018 | 08:15 PM
Tgriffithjr's Avatar
Tgriffithjr
38 to 45 is subjective. It depends on the outside temperature. With r134a the best you can hope for is about 45 degrees cooler than ambient temperature. So if it’s 100 outside 55 is good.
Old Jul 18, 2018 | 05:06 AM
Whine not Walnuts
Delta T of 45.
Old Jul 18, 2018 | 05:25 AM
Tgriffithjr
Delta T of 45.
isnt that what I said?
Old Jul 18, 2018 | 05:29 AM
Whine not Walnuts
Yes but I am pretty sure there are folks here that have no idea what Delta T is.
Old Jul 18, 2018 | 05:30 AM
Tgriffithjr
gotcha
i was attempting to explain in easy to understand terms for those who might not understand what Delta T is.
Old Jul 18, 2018 | 05:37 AM
Whine not Walnuts
A little of topic but there have been a couple of posts recently where the battery was connected up backwards, positive to ground.
Some get upset when they take a question as being an insult to their intelligence but usually the question is because an important part of the problem has been left out.
Stay Curious
Jul 1, 2014 08:48 PM
hansjqrg1
Cooper (non S)
Sep 1, 2010 11:08 AM
ED955S
Electrical
19
Jul 5, 2007 12:37 PM
Prima Car Care
Detailing 101
Oct 17, 2006 11:53 AM
HAL9000
Oct 11, 2006 03:40 PM
