Vacuum hoses
Old Jun 19, 2018 | 12:17 PM
wrigdust's Avatar
wrigdust
Vacuum hoses
So how much of an issue would it be if the big vacuum line is disconnected from the intake pipe on my 03 MCS? I tried putting it back on, but my hands are too big to squeeze the clamp and push it back in simultaneously, I got it pathway back in, but it keeps popping back off.
thanks in advance
Dustin
Old Jun 19, 2018 | 12:29 PM
JABowders's Avatar
JABowders
Veteran: Army
You might start getting a amber SEL (Service Engine Light) from the strange vacuum reading in the system.
Took me a few weeks to figure out where my disconnected line was... turned out to be the one under the intake manifold down by the supercharger. Kept popping the SEL when I hit 3/4 tank of fuel then would clear after I filled the tank. I chased the fuel system lines four times until I found the loose vacuum line.
Motor On!
Old Jun 19, 2018 | 03:31 PM
wrigdust's Avatar
wrigdust
That's the problem, no light...I am just experiencing no power tool about 2500rpm, want sure if that might be it
Old Jun 20, 2018 | 02:36 PM
wrigdust's Avatar
wrigdust
I got the vacuum line put back in, and I sprayed some starting fluid around, and doesn't seem to change the idle, so maybe no vacuum leaks. So what else could be causing such a lack of power till 2500rpm?
Kitsune
Feb 23, 2015 04:38 PM
IzzyG
Oct 24, 2013 09:25 AM
Stu(pid)
Tires, Wheels, & Brakes
Jul 25, 2005 06:28 PM
stever
Mar 22, 2005 08:26 PM
DavidR.
May 1, 2003 08:38 AM
