passenger side mirror glass replacement
Old May 19, 2018 | 10:40 AM
coopermike29's Avatar
coopermike29
Hi
2006 R 50
I need to replace the mirror only.
The replacement piece looks like it just snaps on.
Tried to locate a video of how to...but no luck
Has anyone done one before ?
much appreciated
Thank you
Old May 24, 2018 | 04:52 PM
coopermike29
Anyone ??
Old May 24, 2018 | 05:10 PM
tbmguy's Avatar
tbmguy
I am not sure how it mounts, but today on my 2008 MCD the drivers side mirror glass just fell off and broke.
so i need to get the new glass and mount it. If I figure it out i will let you know what I find.
jfrantz's Avatar
jfrantz
The mirror glass snaps in with plastic tabs. To remove it, simply place a pry-bar between the edge of the mirror housing and the glass, then pry it out. It will pop out so be sure to catch it with your free hand. Make sure the pry bar you use is plastic so as not to damage the mirror housing.
There may be two wires attached to the heating element on the back of the mirror glass. Simply pull those off and attach them to the new mirror.
For installation, just press the new glass into the bracket and it will pop into place.
-Jeff
Old May 25, 2018 | 06:36 AM
coopermike29
Thank you all for your responses.
It seems pretty easy and I do have plastic pry bars.
I'll let all know the results when I replace it.
Old May 26, 2018 | 10:19 AM
Eric_Rowland's Avatar
Eric_Rowland
You can do it just with fingers - just move the mirror all the way in.
Clint Johnson
Jul 9, 2012 03:02 PM
Jeffsmashkot
Jan 26, 2010 06:47 AM
phantasms
Aug 1, 2008 11:49 PM
blaksheep67
Aug 12, 2007 03:19 PM
