P0642 Code Limp Mode Help!!
Old May 16, 2018 | 11:01 AM
jguyer98's Avatar
jguyer98
Hello,
I have a 2005 MCS and been able to find posts with similar problems and solutions as my car, but not the same symptoms. My car goes into limp mode with the Check Engine Light, TPMS Light, DSC light and EML light all on. I turn off the car and turn it back on, and everything goes away except the check engine light. I can drive the car for about a day or two, in this time the check engine light goes off, and then it happens again. It seems to happen only while I'm cruising at a steady speed. It throws the P0642 code, which is a general voltage low code. I replaced the bypass valve thinking that was the problem, but it's still happening. Mods I have are the 15% pulley, Alta cold air intake, and Milltek Catback exhaust. I also have a boost gauge and had to tap into some wires, I was wondering if this could be a potential problem? Any input would be greatly appreciated. I just really want my car to be reliable again.
Old May 16, 2018 | 12:02 PM
Wyitdog420's Avatar
Wyitdog420
Mine is always the gas cap needing tightened.
Old May 16, 2018 | 12:59 PM
Whine not Walnuts's Avatar
Whine not Walnuts
Could be a wheel speed sensor or a knock sensor issue. Some simple things is to disconnect the negative battery terminal for at least 15 minutes. Can also remove and replace the DSC fuse.
ahmedalsurmi
Sep 25, 2023 04:49 AM
Supergreen03
Oct 24, 2014 08:36 PM
tattman23
Apr 2, 2012 09:11 AM
poweredbydvot
May 12, 2010 11:07 AM
