New- low boost
Old Apr 14, 2018 | 01:27 PM
Chet1185's Avatar
Chet1185
New- low boost
Hello. Just bought an 05 mini cooper s 6 speed. Im getting code P1498 and an EML light. There's a boost gauge installed already and I'm,only getting 5lbs boost/ 10 vacuum. I'm thinking I have a leak somewhere? I read that the pipe from supercharger to TB could be the issue?
All the help I get is greatly appreciated. Thank you
Old Apr 14, 2018 | 02:08 PM
Whine not Walnuts's Avatar
Whine not Walnuts
Check to make sure all the clamps are tight from the air cleaner to the throttle body and then check the boots on each side of the intercooler/
Old Apr 14, 2018 | 02:59 PM
Chet1185's Avatar
Chet1185
Ill check every connection.
Old Apr 15, 2018 | 10:43 AM
Chet1185's Avatar
Chet1185
Car has an Alta intake installed. Is that what I'm hearing every time I touch the gas pedal or is that noise a leak somewhere? Its pretty loud
Old Apr 16, 2018 | 10:01 AM
suspencer's Avatar
suspencer
My '05 had the same symptoms, EML + P1498. I fixed it by replacing the MAP sensor and its vacuum line, but it could be coming from a variety of places such as the green supercharger gasket. Also, smoke test is never bad idea.
Itsdchz
Suspension
22
Jul 30, 2008 09:27 AM
biggripper
May 14, 2004 10:13 AM
pooky13
Tires, Wheels, & Brakes
Apr 26, 2003 01:46 AM
