Timing Tensioner noise?
Old Apr 10, 2018 | 07:11 AM
Tiptonite's Avatar
Tiptonite
Hi All,
New member here from Charlotte, NC. I have an 04 MCS with 156k miles. I changed the oil last week and put on a new water pump this past weekend. The car has been driving fine the last few days however, yesterday I drove it to work (ran fine) then when I went to start it 8 hours later, I heard the dreaded timing chain noise (sounded like a diesel). I drove it home (13 miles) very lightly and turned it off for the night, aside from the noise, it ran fine. Started it up this morning and it sounded fine/back to normal. I am assuming it would be the tensioner getting stuck given that i have not changed it and have read about similar symptoms elsewhere. I went ahead and ordered a Tensioner off Pelican Parts, I have another vehicle so I left it home today. I am new to the mini world but I am not new to cars, Just wanted to get some thoughts from the Mini Cooper Gurus. Thank you in advance.
Old Apr 10, 2018 | 07:37 AM
ItsmeWayne's Avatar
ItsmeWayne
before you freak out, replace this:
It is the cam chain tensioner, they get stuck and need replacing, before you harm the engine! It is under the oil filter, just to the passenger side. They had many go bad on the early gen 1 models.
They can be had for under $25.
Old Apr 10, 2018 | 09:08 AM
z_wrecker's Avatar
z_wrecker
Could it be your belt tensioner? Little shock tends to snap at the ends, forcing the little rubber bushing out. It creates metal to metal contact which could sound similar.
Old Apr 10, 2018 | 10:33 AM
Tiptonite's Avatar
Tiptonite
Thank you, this is what I thought the problem was. Is it a common issue for it to become stuck/unstuck?
Old Apr 10, 2018 | 07:09 PM
ItsmeWayne's Avatar
ItsmeWayne
Yes, it gets burrs on the piston and sleeve and if not replaces, could cost you the engine!
Best of luck and don't forget, it can also be a few other things, like chain guides, etc.
Old Apr 10, 2018 | 09:07 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
With 156k you really need to do the complete chain kit. We see this all the time at that mileage the chain is stretched and just putting a tensioner in it will at best be a temp fix. The chain will be slapping causing the noise.
We have a complete kit
https://www.waymotorworks.com/timing...0-r52-r53.html
or get just the individual parts
https://www.waymotorworks.com/02-06-...ts/index3.html
Old Apr 10, 2018 | 09:53 PM
pnwR53S's Avatar
pnwR53S
6th Gear - NAM Hall of Fame
^ Sage advice backed up with experience. I am amazed the chain and plastic chain guide last that long. 156k is a lot of revolutions for the poor engine and gears.
Old Apr 16, 2018 | 05:30 PM
Tiptonite's Avatar
Tiptonite
Tensioner worked
well the tensioner fixed the “death rattle”. I was looking into replacing the chain/guides for preventative measure, will do that in the near future. Thank you all for the help
jonprivate
Aug 2, 2019 11:05 AM
limenuke
Mar 3, 2018 04:39 PM
daonlyillwiz
Feb 4, 2014 06:28 PM
JDCustoms
Jun 14, 2012 08:22 AM
MattSaint
Apr 22, 2010 02:52 PM
