2003 R53 intermittently overheats
Old Mar 28, 2018 | 10:38 AM
ewgoforth's Avatar
ewgoforth
Hi,
My 2003 R53 intermittently overheats when stopped. It seems like the cooling fan isn't coming on early enough? I usually turn off the engine and then I hear the fan come on and the temperature will start to drop. I'm thinking the temperature switch may be bad? Is there a secondary switch or relay that could cause this? I guess I can plug in my OBD sensor and see what the temperature that it sees is currently when it's overheating. There seems to be only one cooling fan? I know some cars have a second one that comes on when the A/C is turned on.
Old Mar 28, 2018 | 11:13 AM
JAB 67's Avatar
JAB 67
You need to do a search on 'Low Speed Fan Resistor . ." Likely explains your problem.
Old Mar 28, 2018 | 12:09 PM
Whine not Walnuts's Avatar
Whine not Walnuts
Flip on your ac and if the fan does not come on the low speed is having issues. Lots of discussion on the matter in the below thread. I have the resistor installed and it does work, I have posts in the thread about it.
https://www.northamericanmotoring.co...-solution.html
Swift
Dec 23, 2013 10:26 AM
ekerley
Jan 11, 2012 03:36 PM
Sin MINI
May 1, 2009 10:17 PM
mplatt911
Dec 8, 2008 09:25 AM
jaehchoi85
Sep 10, 2007 09:26 PM
