Clutch questions
Old Feb 7, 2018 | 12:29 PM
Duaneo's Avatar
Duaneo
Clutch questions
Folks,
I've got an R53 with the 6 speed manual transmission and 205k miles on it. At about 120k miles, I replaced the supercharger pulley with a 17% pulley. At about 150k miles, the original OEM clutch went out. Now at 205k miles, the clutch is going out again. I don't know what clutch the shop put in, but I'm sure it wasn't an expensive one as the whole job was roughly $1700. I don't do any track driving, just "spirited" street driving.
I have a couple of questions.
1) Assuming my driving style didn't change significantly after the new pulley, did the new pulley create a situation where the new clutch wore out more quickly?
2) Does the JCW model have a different clutch than the regular S? Should I look into a JCW clutch to go with the 17% pulley?
3) Prices for clutch kits range from $150 to $1700. Can someone explain the relative performance differences between these clutches? What would be appropriate for a spirited street driver as replacing the clutch appears to be a PITA and I would prefer do the work as seldom as possible.
Thanks in advance for your advice!
Cheers,
Duane
Old Feb 7, 2018 | 11:08 PM
BlwnAway's Avatar
BlwnAway
1) No
2) No
3) For your use just go with the Valeo OEM replacement.
You're not making near enough power to be considering $1k clutches.
Did the other shop replace the flywheel as well? An uneven, scuffed or surface damaged flywheel, can wipe out a new clutch real quick.
SavageTyler
Jun 12, 2014 12:16 PM
DreamMini
Oct 15, 2011 11:55 PM
Black Boots
Jan 2, 2010 12:51 PM
Blazermaniac
Sep 24, 2007 01:17 PM
RA080624
Oct 25, 2006 01:39 PM
