shake rattle and roll
Old Jan 4, 2018 | 09:30 AM
bneer's Avatar
bneer
hoping someone else has had this issue, when the temps drop my R53 rear end sounds like it is going to rattle off. The Megan coil overs are suspect but it is getting to the point where people on the street can here it popping and rattling. Haven't had a shop yet locate the problem. Feels like rear end is loose. Thanks
Old Jan 4, 2018 | 10:00 AM
Whine not Walnuts's Avatar
Whine not Walnuts
Have you checked the suspension including the end links?
Old Jan 4, 2018 | 11:20 AM
bneer's Avatar
bneer
shake rattle roll
Thanks for reply will have links checked.
Old Jan 4, 2018 | 11:24 AM
gumbedamit's Avatar
gumbedamit
Let me know what you find, I've removed my struts twice trying to figure out what is causing this issue. New struts about 9 months ago, checked all the bushing which seem to all be in good order..
Old Mar 5, 2018 | 11:08 AM
bneer's Avatar
bneer
This weekend I replaced rear sway bar end links and added power flex trailing arm inserts. Had no effect on rattle and pop. will do lower rear control arms next. Also replaced lower front ball joints. If you have 80000plus miles as I do you may want to replace yours. They were very worn, front feels better.
Old Mar 5, 2018 | 02:43 PM
Thinker2112's Avatar
Thinker2112
I also have Megans and they make the "rattle." I tend to think of it is more of a clunk. I will try to get a video up loaded soon. I have a few but I am at work and typing this is about all I can do from here. On the video, the clunk sounds a bit like someone is gently tapping on an open mic, but the sound I reality it a bit more like a metallic clunk.
Old Mar 6, 2018 | 05:39 AM
Subw00er's Avatar
Subw00er
Could it be the spring spinning around? Is there a way to add a plate to them to quieten them down? I know some coilovers have plastic sheets to let the spring twist a bit.
How do you guys like the Megan otherwise? Im about to put a set of EU on when the weather turns.
Old Mar 6, 2018 | 06:33 AM
bneer's Avatar
bneer
My noise started when temps dropped below 60 degrees. Each year it gets worse. If the Megans are the culprit it is a waste of money to buy them. The racket Im getting ruins the driving experience. I would like to hear from other Megan coil over owners regarding this issue. Im still going to make suspension upgrades but so far I've managed to tighten up the suspension and intensify the rattle and pop.
Old Mar 6, 2018 | 07:08 AM
Thinker2112
The spring bind is more of a bong sound. That doesn't bother me at all because you know... racecar. It can be cured with a little grease on the spring perches, again, something that I just haven't done. The clunk is a concern though. The lower pillow ball bearing may be the issue. I haven't had the time to pull the coil over off to really see. Otherwise, I have really enjoyed the Megan's for the last 5 years. They have been, until now, essentially trouble free. The first month I had them, the same front left corner made the same sound but that was my fault to make sure that all nuts were tightened. I have tightened it down and now it only makes the noise on either harsh abrupt bumps or very very light undulations in the road.
Old Mar 7, 2018 | 09:39 AM
bneer's Avatar
bneer
My noise has always come from the rear suspension both sides. Installed coil overs about 10000 miles ago in late summer. When winter hit the rattle began. I had coil overs checked for tightness and they were. Friday will try and replace lower control arms. Thanks for the input
Old Mar 10, 2018 | 09:21 AM
bneer's Avatar
bneer
Shake rattle an roll
changing lower control arms today how do I clear lower brake line bolt against it.
Old Mar 26, 2018 | 08:05 AM
bneer's Avatar
bneer
Okay, I pulled passenger side rear coil over to lubricate it .Didn't have a vice so couldn't loosen top nut. I did spray a lubricant on all mating surfaces. Reinstalled and had a real reduction in rattle noise. Ordered a vice a will get grease. What are the pitfalls ahead of me? Thanks for all the support.
Old Apr 21, 2018 | 06:40 AM
bneer's Avatar
bneer
Shake rattle and roll
rattle back on steroids. Put car on stands pulled wheels reached in and grabbed sway bar. Gave a pull and it slid in bushing about a quarter inch in travel. Should this happen?
Old Apr 21, 2018 | 08:04 AM
pnwR53S's Avatar
pnwR53S
6th Gear - NAM Hall of Fame
You are not clear if 1/4" travel is vertical or horizontal. If vertical it is at least one source of your misery. Horizontal travel is not good either, and that is why I chose a sway bar with built in lateral stops.
You should not be able to move the sway bar with your hand in any form or fashion in a healthy bar, bushing, and end links; even with the stock toy bar.
Old Apr 23, 2018 | 07:01 AM
bneer's Avatar
bneer
got the car on stands and found left rear end link had loosened up. thought it was torqued down pretty good. The sway bar movement was horizontal, found one of the clamps that i was able to crank down on a little. It is a H&R swaybar 19mm. The right end link was pretty tight but was able to snug it up a little. Checked everything else I had installed for tightness, seemed good. Got the car down and within a matter of feet a could still here a rattle. Concentrated more in the right rear. I'll keep looking. Thanks to all the responders.
cxg
48
Jun 29, 2009 02:10 PM
MINI MANIAC
Feb 4, 2009 12:22 PM
blalor
MINI Camera and Video
Mar 22, 2007 07:20 PM
xbritt
Dec 6, 2004 02:08 PM
e12pilot
41
Oct 27, 2004 01:00 PM
