Sc broken teeth
Old Dec 25, 2017 | 04:43 PM
tonymtorres47@hotmail.com's Avatar
Sc broken teeth
so I broke a tooth on the supercharger where it connects with the water pumps can it be replaced or can still operate the same with one tooth
Old Dec 26, 2017 | 05:24 AM
Whine not Walnuts's Avatar
Whine not Walnuts
Moved to the Stock Problems/Issues area.
You pry the pump out without first removing the flange bolts at the motor block where the water enters?
Old Dec 26, 2017 | 09:50 AM
AoxoMoxoA's Avatar
AoxoMoxoA
Yikes!
I can't imagine what one would have to do in order for one of the water pump drive tabs to actually break off...
Old Dec 26, 2017 | 10:32 AM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
I've seen this before and it's usually from pulling the pump off with the supercharger still bolted to the block due to the tilt you put on the pump. So I would try to find a new rear section to rebuild the supercharger with and make it right.
Also make sure you clean the block up before installing the flange as that looks really bad.
Old Dec 26, 2017 | 12:50 PM
Whine not Walnuts
Was waiting for a seasoned pro to chime in and Way Motors fits that bill to a tee.
cmross13
Aug 25, 2014 12:18 PM
Mini1966
22
May 14, 2008 07:47 AM
JammyCooper
Jul 27, 2007 05:09 AM
