New member - question regarding water pump/coolant temps
Old Dec 14, 2017 | 08:56 AM
  #26
ItalianJobR53's Avatar
ItalianJobR53
Originally Posted by pnwR53S
A sticky thermostat will not necessary cause the housing to leak. BTW, I did a web page search for "thermostat", and saw no hit.
I am not convinced that you verify the low speed fan functionality. You inferred a lower level sound and assume it is low speed fan coming on.
You can perform a easy test for the low speed fan by measuring the resistance WRT ground at the connector. Both high speed and low speed hot side should read like death short. If one is open, it is 99.99% the resistor has gone kaputt.
I'll measure the reisitance
Old Dec 14, 2017 | 09:12 AM
  #27
Whine not Walnuts's Avatar
Whine not Walnuts
Shine a flash light between the engine and the radiator. If the fan is spinning you will see it.
Old Dec 14, 2017 | 10:49 AM
  #28
ItalianJobR53
Will check today evening
I did not think that there was enough space to take a look
bimpower
May 14, 2013 03:33 PM
Little Bean
R55 :: Clubman Talk (2008+)
Dec 26, 2012 03:23 AM
ROOSEY
Nov 16, 2012 11:57 AM
andy@ross-tech.com
Apr 9, 2004 06:17 PM
greatgro
Dec 2, 2003 01:22 PM
