Supercharge smell
Old Dec 9, 2017 | 11:34 AM
GordoR53-702's Avatar
GordoR53-702
Supercharge smell
Hey guys I’ve recently noticed in my 06 MCS whenever the supercharger kicks in smells like burnt, is this a sign that I need to do an oil change to it ?
Old Dec 9, 2017 | 02:45 PM
Whine not Walnuts's Avatar
Whine not Walnuts
Going to move you to the Stock Problems/Issues area.
How many miles on the car? Could it be a belt slipping due to a bad crank pulley?
Old Dec 9, 2017 | 07:09 PM
GordoR53-702
it recently hit 120k the other day. And could that be the reason to the smell?
Old Dec 10, 2017 | 03:52 PM
kaneguy's Avatar
kaneguy
Yep, that is probably what you are smelling. On the R53 the Supercharges does not "kick in", it is always being driven off the crank, so is always spinning. The only thing that changes is the RPM. You will hear the S/C whine at the higher RPM. Check the belt and tensioner, one or both may need to be replaced. At that mileage, If it hasn't been done yet I would highly recommend servicing the S/C and changing the oil.
Old Dec 11, 2017 | 06:53 AM
nkfry's Avatar
nkfry
If you've not replaced the crank pulley yet I would inspect it for failure, when they fail you'll get a burning rubber smell, which is usually accompanied by a SES light, battery light, low power, etc., but you could also have an oil leak that when the engine is warmed up is giving you an odor, my car had a small oil leak that was just enough to make the filter housing tacky and when I drove hard I would get the smell of burning oil in the cab.
I would assume if you had a fault with the SC that caused a smell that you would also have an apparently horrid noise coming from the SC as well.
Phone:586-792-6464
Info@DetroitTuned.com
Nick@DetroitTuned.com
RudeJoe
16
Jan 12, 2017 11:38 AM
brody78
12
Oct 10, 2012 08:37 AM
Red_5
Off-Topic :: Autos
Sep 28, 2005 11:25 AM
CooperSdriver
Aug 25, 2003 05:33 AM
Graham
Apr 8, 2003 06:53 AM
