R56 Door Sill Plate Lifting
Old Nov 28, 2017 | 09:01 AM
Cab00se's Avatar
Cab00se
Has anyone found a good replacement for the adhesive on the door sill plates? My driver side was lifting so I removed it this morning to prevent it from getting jammed in the door and damaging the paint and just wondering if anyone has found a good replacement so I won't be doing this again in a couple months. Also do they flatten back out pretty well? Mine holds a lazy U shape now.
Old Nov 28, 2017 | 12:53 PM
Some double sided tape works but if they are pealed up or bent really bad I would just get new ones. They tend to crease on the metal and leave a bend mark. As long as they are not bent 3M double sided tape works good.
https://www.ecstuning.com/Mini-2007-...nterior/Door/3
The factory ones have a foam version double-sided tape. Make sure you clean the surface with alcohol wipes first
Old Apr 25, 2018 | 01:13 PM
mosherrskl's Avatar
mosherrskl
Mine are peeling from both ends. I'm planning to use my hot glue gun
