5th Clutch Slave Cylinder Replacement in 3 Months
Old Nov 5, 2017 | 09:18 AM
RedRidingHood's Avatar
RedRidingHood
Well... As the title states, I am on my 5th clutch slave cylinder replacement in 3 months and the same issue keeps occurring. The plastic rod inside of the boot of the slave keeps bending, causing a fluid leak and total loss of pressure in the clutch. Is there a slave cylinder that exists that has a stainless steel rod instead of plastic?
I have already had the entire clutch assembly replaced, as well. This last slave didn't last 10 miles and I am pulling my hair out! I need help!!
Old Nov 5, 2017 | 09:44 AM
Whine not Walnuts's Avatar
Whine not Walnuts
Moved you to the Stock Problems/Issues area.
It would be logical to assume that something is causing resistance that the plastic plunger rod cannot accept. Hopefully somebody here has some better suggestions.
Old Nov 5, 2017 | 10:17 AM
pnwR53S's Avatar
pnwR53S
6th Gear - NAM Hall of Fame
Unless you have a aftermarket high performance clutch kit that taxes the Mini's toy plastic slave cylinder there is absolutely something wrong with you clutch you should investigate. For me I dislike light clutch pedal but for our Mini it comes with the territory being mini. The only high performance clutch kit that I am aware that will give me the preferred clutch pedal feel and I will feel comfortable is OS Giken. Unlike other "high performance and flywheel kits" they are the only company that I am aware that designed and makes a special release bearing for the increase pressure plate force. Sorry, the release bearing is another weak link in the chain, and is not your problem but I thought I mention it.
There is a aluminum slave clutch cylinder you can buy for circa $100. I would think it is a waste of money if you don't have a race clutch kit.
