Help troubleshoot auto sensing wipers inoperative
Old Oct 29, 2017 | 04:18 PM
Subw00er's Avatar
Subw00er
I have the box on my windshield. When I click it to the first position on the stock (gen1 r52), it operates the wipers just once, then they dont go on again, even in heavy rain at speed.
Does this have to be a sensor problem?! Do they ever go bad? I have an afternarket windshield but it looks like the lens etc is attached and they put the correct windshield on.
How does the cover for the sensor come off? Just pull? Maybe its just not plugged in!
Old Nov 12, 2017 | 04:44 PM
Subw00er's Avatar
Subw00er
bumping this... anyone?
Old Nov 12, 2017 | 05:33 PM
Whine not Walnuts's Avatar
Whine not Walnuts
Moving to the Gen1 Stock Problems/Issues area.
Old Nov 13, 2017 | 09:47 AM
Its attached to the window with a sensor. The Sensor lens itself is in the glass. If the box does not sit tight on the glass the sensor will not see the water. Same part on the gen 2 MINIs as the gen one on the box part. Windows are different. This guy has a retrofit but the OEM part numbers are the same.
61356923954
https://www.northamericanmotoring.co...-retrofit.html
Old Nov 13, 2017 | 02:55 PM
Subw00er's Avatar
Subw00er
ok ill check that thanks.
Old Nov 14, 2017 | 05:23 AM
Welcome.
