What else do i need to do when doing clutch job
Old Oct 27, 2017 | 08:48 PM
yyj3869's Avatar
yyj3869
I have 03 mini cooper s with 86k.
I'm planning to replace current stock clutch with valeo clutch conversion kit (including flywheel)
since the mini specialist (the shop) drop the subframe, I will also do control arm bushing (PSB) and supercharger oil. When they replace the flywheel, is it better to replace Rear Engine Main Seal as well? link below
Amazon Amazon
What else would I need to do?
Old Oct 30, 2017 | 07:35 AM
megaDan's Avatar
megaDan
Depends on the state of the car. Given that you're in so-cal you probably won't need to replace things due to rust like I did. I replaced all ball joints, end links, tie rods, etc. Inner CV boots, release bearing, and rear main are good ideas too. I'm at 106k with a questionable history. While you're in there it would be a good idea to address these items for peace of mind.
Old Oct 30, 2017 | 11:47 AM
yyj3869's Avatar
yyj3869
Yeah the car is located in socal now. It used to be NM before.
I currently replaced CV Axle on passenger side. Do you think inner and outer ball joints also need to be replaced when replacing control arm bushings?
I found one from ebay. I think this is really cheaper than other products.
https://m.ebay.com/itm/4-X-DLZ-Suspe...19.m1438.l2649
Old Oct 30, 2017 | 12:08 PM
megaDan's Avatar
megaDan
Personally? I'd say yes. They're cheap enough to be a 'while you're in there' type of item and the OE threads are quite fragile. There's a good chance of damaging them upon removal. Not a fan of Ebay components, but at the same time I frequent Rockauto so I'm not sure if my opinion is valid.
Old Oct 30, 2017 | 04:11 PM
Whine not Walnuts's Avatar
Whine not Walnuts
Some good info here, moving you to the Stock Problems/Issues area.
Everyone should experience road salt rot then they will really appreciate living in a road salt free area relative to their car.
Old Oct 30, 2017 | 04:25 PM
yyj3869's Avatar
yyj3869
I really appreciate your opinion!. I might have to go for those from ebay.
Old Nov 1, 2017 | 11:14 AM
sarom058's Avatar
sarom058
From: Portland, OR *currently in a temporary email address
Here's what I ordered when I did my transmission swap a few weeks ago. Best ball joints are Lemfoerder brand on PelicanParts.com. Best LCA bushings are PowerFlex, available cheapest on Waymotorworks (last I checked).
https://www.northamericanmotoring.co...-pep-talk.html
Old Nov 1, 2017 | 11:29 AM
yyj3869's Avatar
yyj3869
What happened to your gearbox? I’m kinda scared that my gearbox will be broken soon. It happens a lot for mini?
Old Nov 1, 2017 | 12:41 PM
sarom058's Avatar
sarom058
Not for Getrag 6-speeds. They're generally bulletproof transmissions, but I bought mine with a damaged input bearing and 4th/6th gear synchros. It whined like crazy in neutral with the clutch engaged, and 4th/6th screamed.
If you drive it and there's no weird noises, crunches, or other symptoms, and you're changing your fluid every 50k miles or so, you should be totally fine, like everyone else on this forum. I just have the R53 from hell, lol.
Old Nov 1, 2017 | 01:26 PM
yyj3869's Avatar
yyj3869
I bought this car from NAM member and it was my first driving manual. now i'm used to shifting gear but I always wondered if I shift gear from 1st to 2nd, I can hear the clunk noise, one of my friend who used to drive vw gti manual, he said it's normal but it is little annoying.. is it really normal?
Old Nov 1, 2017 | 02:03 PM
pnwR53S's Avatar
pnwR53S
6th Gear - NAM Hall of Fame
It is not normal. Cause can be synchromesh is worn, again not normal. If you are in cold locale I might suggest trying thinner synthetic gear oil, but not S Cal. If the clutch is dragging that can also cause hard shifting.
Old Nov 1, 2017 | 02:06 PM
yyj3869's Avatar
yyj3869
Originally Posted by pnwR53S
It is not normal. Cause can be synchromesh is worn, again not normal. If you are in cold locale I might suggest trying thinner synthetic gear oil, but not S Cal. What is the mileage?
it has only 86k miles. 2003 mini cooper s. I bought redline 75w-90 with valeo clutch conversion kit. I can hear shifting sound from the bottom when I shift.
Old Nov 1, 2017 | 02:22 PM
pnwR53S's Avatar
pnwR53S
Let's just hope your existing clutch is dragging. Mini has no pilot bear to seize and drag. I bought Redline MTL and the gear change is noticeably lighter.
Old Nov 1, 2017 | 02:26 PM
yyj3869's Avatar
yyj3869
Yeah hopefully everything is okay. Thank you so much for the info!!
