Hood/Hatch warning light stays on
Old Oct 21, 2017 | 09:18 AM
Rgallic's Avatar
Rgallic
2005 Mini Cooper S
Hood/Hatch warning light stays on.
I'm trying to sort out which end may be at fault.
If the hatch switch were failing would the interior light stay on?
Where is the switch for the hatch?
Old Oct 21, 2017 | 03:00 PM
Whine not Walnuts's Avatar
Whine not Walnuts
Going to move you to the Stock Problems/Issues area.
In the FAQ section, the first thread will include a section on how to look up parts. Item 0014 has a link to Realoem that has templates on all the different portions of the car.
Old Oct 21, 2017 | 08:06 PM
Rgallic's Avatar
Rgallic
Figured out the problem, thought I'd share should anyone else run into this.
Turned out to be the hood sensor switch, appears to be shorted.
I unplugged the cable, light went off.
Needs a new switch.
Old Oct 22, 2017 | 04:40 AM
Whine not Walnuts
Good to know, switch is on the passenger side latch?
Old Oct 22, 2017 | 05:16 AM
CSP's Avatar
CSP
Easy troubleshooting! Thanks for following up on the thread. Enjoy being warning light free!
Old Oct 22, 2017 | 05:44 PM
Rgallic's Avatar
Rgallic
Yes, I took it out, checked it with an ohm meter. Odd, I expected the switch to fail open. This one appears to be stuck closed, little change when I press the plunger. For now I'm just leaving it unplugged.
