P2803 OBD Code??
P2803 OBD Code??
Hi all. 2006 R50 is throwing a few codes....P2803 (Manufacturer Defined), P0100 (Mass or Volume Air Flow Circuit), P0036 (HO2S Heater Control Circuit).
I know what the last two are, but can't find info about the P2803 (Manufacturer Defined) code.
Any ideas?
Thanks.
Any ideas?
Thanks.
It's definitely a P and not a B. I have the dreaded CVT trans which is acting a little strange as of late; "Jerks" as I pull away from a stop. The "jerk" is really bad when going from reverse to drive. Seems to get a little better as the car warms up.
I purchased the OBD reader last week after the car started misfiring a bit. I think the prob was corrosion on the #3 connection on the coil. I gave it a good cleaning with some steal wool and it runs fine now. Funny thing is, the transmission seem to act up after I had the oil change......not sure if that is related or not.
Are the OBD codes make and model specific? In other words, would a P0036 mean something different on a Jeep or BMW?
Thanks.
Thanks.
The " jerking" motion could be a software corruption caused by low voltage during cranking.
Most times a NEW battery will resolve.Along with software and readapting.
coastmotorwerk.com in California has more info.
Good Luck
Good Luck
