Engine Swap
Old Aug 14, 2017 | 12:25 PM
Burn out's Avatar
Burn out
Engine Swap
I did an engine swap due to a bad rod. The computer worked fine prior to swap and now is popping the DME is faulted and I am sure it is causing many of the other codes. I had a bad injector fixed that. It is surging and it sounds like a blow off valve is popping. Any ideas on any type of reset due to engine swap? The DME shouldn't have gone bad being disconnected.
Old Aug 14, 2017 | 12:31 PM
Whine not Walnuts's Avatar
Whine not Walnuts
What year car you have? The R52 in S trim is a supercharged engine that is not goign to have a blow/pop-off valve that turbo has.
Old Aug 14, 2017 | 12:35 PM
Burn out's Avatar
Burn out
I believe it could be the fuel pressure regulator?
Old Aug 14, 2017 | 12:39 PM
Whine not Walnuts
How did you disconnect the power, pulled the negative terminal off? What codes are you getting?
Whine not Walnuts
Moving you to Stock Problems/Issues area as well.
Old Aug 14, 2017 | 12:55 PM
Burn out's Avatar
Burn out
Yes it was disconnected at the battery and it is new with 13.3 volts being measured
Old Aug 14, 2017 | 12:58 PM
Whine not Walnuts
OK, what codes you getting? You are sure all your electrical plugs and grounds are connected/tight? Hose clamps at throttle body and BPV are tight?
Old Aug 14, 2017 | 03:43 PM
Burn out's Avatar
Burn out
Yes ground is back on and plugs are tight my water temp plug would be only but that isn't an issue I will have to get on my schwaben scanner and look at what codes are pulling. The scanner is new to me so I haven't played with it to much.
Old Aug 15, 2017 | 09:23 AM
Burn out's Avatar
Burn out
codes that popped up are 21,63,64 1109 and 1242
Old Aug 15, 2017 | 06:19 PM
Whine not Walnuts
Codes are 4 digits/letters, P1109 is the MAP sensor ( signal too high under decel) and is usually due to either a stuck throttle valve or an air leak. P1242 is MAP sensor # 2 same too high under deceleration and same cause.
