Sliding switch behind emergency brake handle
Old Apr 18, 2017 | 07:51 PM
Thumper Simpson's Avatar
Thumper Simpson
Can't find mention of it in owners manual. Seems to activate a pump. ABS?
06 convertible automatic, not S
Old Apr 18, 2017 | 09:10 PM
RB-MINI's Avatar
RB-MINI
Do you have a pic? The only switches I've seen around the emergency brake handle are the mirrors and seat heaters, the tire pressure reset switch, and the driving light switch if the factory extension cable was used to relocate it. Behind the brake lever should be the rear cup holder.
Old Apr 18, 2017 | 09:29 PM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
Is it to reset the Tire Pressure Monitor.
Old Apr 18, 2017 | 09:48 PM
RB-MINI's Avatar
RB-MINI
That area doesn't exist on an '06. The console changed in 2005 and the tire pressure reset is on one side of the brake lever, and a switch blank is usually on the other side, unless the driving light switch was relocated using the optional harness. The console was extended with the built in tray to butt up against the shifter console and the mirror switch plate.
If he does have that console, maybe one of the previous owners replaced the center console with a pre FL console.
Old Apr 18, 2017 | 10:03 PM
-=gRaY rAvEn=-
Moderator
I see...well then I haven't the foggiest of what it could be then.
Old Apr 19, 2017 | 10:10 AM
Thumper Simpson
My bad: its just behind the mirror switch!
Old Apr 19, 2017 | 10:21 AM
RB-MINI's Avatar
RB-MINI
The silver slider below the joystick? That's to switch between adjusting the passenger mirror and the driver's mirror.
Old Apr 19, 2017 | 02:00 PM
Thumper Simpson
Shows how old I'm getting. I KNEW that and had USEDit!
Old Apr 19, 2017 | 02:13 PM
Capt_bj's Avatar
Capt_bj
Old Apr 25, 2017 | 12:10 PM
Yep, its easy to forget. Hey that's my MINI before I changed over to the wood dash.
