Is it really necessary to replace all the radiator hoses?
Old Jan 27, 2017 | 02:34 PM
madmike007's Avatar
madmike007
I'm having a lot of maintenance work done to the MINI and I asked for the radiator hoses to be checked. The mechanic said they are soft and recommend replacing. I don't have any cooling issues, just trying to be proactive. What is the typical lifespan of radiator hoses?
My experience with maintenance is to replace all, but this is not a cheap service. I did not realize there are so many hoses. Do I need to replace all?
I'm at 80k miles. Thanks in advance.
Old Jan 27, 2017 | 03:31 PM
pkunk's Avatar
pkunk
My '94 Dodge diesel with several thousand miles still has the original hoses and I've never given a thought about replacing them.
Old Jan 27, 2017 | 04:25 PM
Fly'n Brick's Avatar
Fly'n Brick
Once he's got it in service mode you might as well take care of it and maybe a few other 'pro-active' things while he's in there. When was the serpentine belt last replaced? PS hoses? A few bucks and peace of mind.
Old Jan 27, 2017 | 07:29 PM
JAB 67's Avatar
JAB 67
In my experience - which is admittedly limited - the ones to worry about are the ones on either side of the upper bleed screw, that feed into the upper radiator inlet.
Old Jan 27, 2017 | 08:31 PM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
It will only matter when one bursts on you. They aren't lifetime parts. Ten years is long service life for high temperature rubber hose.
I've done late night hose rescue for people in the past, not fun.
Old Jan 27, 2017 | 10:21 PM
madmike007's Avatar
madmike007
Thanks for the feedback. I'm very proactive about maintenance. Nothing goes for more than a year without being addressed. The main reason why I posted the question is because the cost to replace all the radiator hoses is about $850. Which to me is ridiculous, but that's replacing everything. I bought the car new and have always maintained and exceeded the normal service intervals. I'm having a hard time justifying the cost on a vehicle that has 80k miles, but I realize the radiator hoses don't last forever.
Old Jan 27, 2017 | 10:42 PM
Shawnnn's Avatar
Shawnnn
I vote no.
You can go crazy replacing every part on the car just because it's old.
Also a radiator hose will always be easy enough to replace if it goes bad.
If $850 isn't a lot of money to you I guess it can't hurt to do it, but I'm sure the hoses are perfectly fine.
Old Jan 27, 2017 | 11:06 PM
madmike007's Avatar
madmike007
Originally Posted by Shawnnn
I vote no.
Thanks for the honest insight. $850 is a lot no matter who you are. I just want to be maintenance free for at least a year (which never happens). I have never spent so much money maintaining a car before, but this MINI is so much fun to drive that I can't help myself. Could have bought two more MINI's for the price I've paid in maintenance, but nothing beats knowing I can have fun without being worried about breaking down!
Old Jan 28, 2017 | 04:42 AM
JAB 67's Avatar
JAB 67
Shawnnn above writes not to worry, that a burst radiator hose is 'easy enough to replace.' Not true. Some of the ancilliary hoses are extremely difficult to reach without a major disassembly.
Old Jan 28, 2017 | 10:50 AM
madmike007's Avatar
madmike007
What does everyone think about replacing the hoses on the link below? I am assuming the labor is much less with this option. Or should I just bite the bullet and replace all?
http://www.realoem.com/bmw/enUS/show...diagId=17_0233
Old Jan 29, 2017 | 08:13 AM
Mini_Chan's Avatar
Mini_Chan
My car has over 100k miles and still on stock hoses. The coolant tank is what usually needs to be replaced before the hoses since they tend to crack.
Old Jan 29, 2017 | 08:37 AM
Scudder44's Avatar
Scudder44
'Soft' hoses are usually a good sign, hard brittle hoses, panic!
Old Jan 29, 2017 | 09:43 PM
*CharlieHustle's Avatar
*CharlieHustle
05 MCS with 144k miles... Still on original hoses. Was on original water pump as well until I decided to pull the supercharger and refill with oil. Only things replaced on the cooling system were the pump, block flange, and the hose from the water pipe to the pump. All the other hoses appeared to be ok. The only reason I replaced the hose was due to the location of the hose and ease of replacement at that point in time. In general, I dont think a radiator hose has a life expectancy. So many factors determine the longevity of an auto part.
I'd vote to skip on the hose replacement. Maybe consider it later down the line when its time to replace the water pump. But at 80k miles, I'm not sure I could justify replacing hoses for preventative measure. Maybe if the hoses looked swollen near the clamp or felt crunchy when squeezing them, I'd lean towards replacement.
Old Jan 30, 2017 | 08:52 AM
madmike007's Avatar
madmike007
Thanks for the detailed response Charlie. I will check hoses with the mechanic today and see how they feel. Based on all the feedback, sounds like this is not a typical failure item.
Thanks to everyone for their input.
Old Feb 10, 2017 | 05:45 PM
madmike007's Avatar
madmike007
Decided to rebuild the super charger with Stiegemeier and also opted for the porting. Since I was in there, I decided to go ahead and replace the water pump and all the coolant hoses. It's a costly maintenance decision, but the insurance of knowing that I will not have to worry about this for many miles to come is worth it. Looking forward to getting DIET SUV back soon. Thanks again for all the input!
Old Feb 24, 2017 | 09:55 AM
zsqure's Avatar
zsqure
If you can DIY, the water pump super kit from pelican parts is just a little over $250, which includes many of those hoses if not all of them AND the water pump. There is some work involved, these little things are easy to work on, they take LOTS of patience.
