Help!. High beam doesn't turn on!
Old Apr 24, 2016 | 09:08 PM
amitayuth's Avatar
amitayuth
Hi Folks, I searched a lot and could not find an answer or a hint on what is going on with my MCS coupe '12 headlights.
The headlight Low Beam works fine on both sides and when I pull the switch to turn on the High Beam temporarily, it actually works fine but when I push the switch to turn on the High Beam permanently then it does not work and other light also turn off even though the blue light indicator on the dash shows it is on
I would really appreciate any help or input on what to do or where to look for the problem. Thanks
Old May 2, 2016 | 09:13 PM
renchjeep's Avatar
renchjeep
Did you buy the car used? Is so, perhaps previous owner installed some kind of aftermarket headlights without the ability to hold high beam. After looking into headlight upgrades for my 2011 with halogens, I see a lot that say "flash-to-pass only, unable to hold high beam" or something similar. Like the Spec-D lights. If still stock, no idea, sorry.
Old May 2, 2016 | 10:12 PM
ZippyNH's Avatar
ZippyNH
Yeah...check for aftermarket headlights....many are low beam only...with a flash to pass...kinda crappy...but for a certain crowd that wants to look like they have $$$ hid's....they like them...
Old May 2, 2016 | 10:51 PM
amitayuth's Avatar
amitayuth
wow.. yes I bought the used car at autonation. I have to check my headlights.
so can you let me know that I have to check my headlight bulb? or headlight assembly?
Thank you for your help!!
Old May 2, 2016 | 10:55 PM
amitayuth's Avatar
amitayuth
Thank you so much. I have to check that.
Old Feb 6, 2019 | 09:55 AM
Flyingspur's Avatar
Flyingspur
High beam troubles
Dear Amitayuth , I hope you can help me out ? I got exact the same problem as you .. when I bought the car there where mini original HD bi installed ,
now high beam on hold is not working , when I push al lights go out... when I pull high beams are working.
I bought brand new h4 units but the problem would be the same.. I hope you've got the right answer ?
thanks so far !!
MarkRNH
Aug 31, 2018 10:54 AM
200hpclubmember
Apr 4, 2016 12:08 PM
mini merle
Apr 4, 2016 07:52 AM
cl_reatta
Apr 1, 2016 08:43 PM
imbrilliant
Apr 1, 2016 04:05 PM
