Spark plug broke, now I'm panicking!!!
Old Jan 29, 2020 | 08:12 PM
  #26
Doron Segal's Avatar
Doron Segal
Happened to me today
I want to replace my spark plug and seems like the person before close it too strong.
looking for a way to extract the gasket out... worse case scenario I’ll take it to the mechanic
Old Jan 29, 2020 | 10:58 PM
  #27
giorgos's Avatar
giorgos
BMW prescribes the use of extensions with joints for unscrewing and screwing of spark plugs in R56 engines.
Quote:
Flexible ratchet extensions must always be used. If rigid mounting tools are used, there is a risk of insulator breakages.
Note: Also do not use a variable plug connection with locking capability as this also poses a risk of insulator breakages.
https://www.newtis.info/tisv2/a/en/r...-plugs/HjUvx2d
Old Mar 15, 2020 | 06:01 PM
  #28
404's Avatar
404
I just sheared a plug off, same basic thing. Below the gasket, snapped the porcelain off, too. Obviously got to buy a torque wrench in inch-feet for this task (was using a high-range wrench at its lower end, couldn't feel it hit 17 ft-lbs and snapped it with ease), but I wouldn't have thought to use a flexible extension without seeing this. I can only hope that tomorrow is decent enough weather for me to spend all day extracting the pieces of porcelain/electrode which are hopefully intact in there, back that plug out and install to correct torque.
Old Mar 21, 2020 | 06:16 AM
  #29
MiniManAdam's Avatar
MiniManAdam
Community Builder
I would have take a rod of some sort and the strongest epoxy I could find and glued the rod to the end of the plug and let it fully cure and then hope it backed it out without breaking the epoxy seal.. just a thought .
terryb237
Nov 24, 2015 01:17 AM
ieandro
Jul 28, 2015 10:42 AM
Gizmo
Classic Mini Talk
Oct 10, 2011 09:53 AM
minimadness
Electrical
May 15, 2009 01:29 PM
Petrich
Mar 16, 2004 05:33 AM
