R50 idle problems
Old Mar 15, 2016 | 12:25 AM
redh4t's Avatar
redh4t
R50 idle problems
Hello,
I own Mini R50 2003 and i have a problem with car vibrating when idle.
If i start the car when it is not warmed up it idles about 1200~1100rpm (no vibration noticed) but after driving for few minutes it warms up and idles with 800rpm.
When idling at 800rpm i can feel a vibration when sitting inside. It drives me crazy.
Maybe someone had such a problem or maybe have a clue what could be wrong? Thanks.
Old Mar 15, 2016 | 07:38 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
Is your check engine light on at all?
888.280.7799 | 6am - 5pm PST
Old Mar 15, 2016 | 07:42 AM
redh4t's Avatar
redh4t
No, all lights is off. Engine check light was on like month ago, but it was because of lambda sensor.
Old Mar 15, 2016 | 07:44 AM
PelicanParts.com
Vendor
When's the last time you did a basic tune up? How many miles are on your R50?
Old Mar 15, 2016 | 07:46 AM
redh4t's Avatar
redh4t
What do you mean by tune up? My mini has like 150 000km., but i am not sure it is legit.
Old Mar 15, 2016 | 07:57 AM
PelicanParts.com
Vendor
Sorry, when was the last time you replaced the spark plugs, wires, and ignition coil? Engine air filter?
Old Mar 15, 2016 | 05:24 PM
Khai's Avatar
Khai
Could bad motor mounts cause the idle to dip? My 02 r50 idles at 1k when warm, never strays up or down in the slightest.
Old Mar 15, 2016 | 11:13 PM
redh4t's Avatar
redh4t
Engine air filter last summer, never replaced wires and ignition coil, but as i remember there was something wrong with wires, because car was twitching when on gas pedal at low rpm, so local car service cleaned the wires or so.. and problem was solved. I think he might change some spark plugs but i do not sure .. i must document every visit at car service because i forget everything ..
So you think this could be something with ignition? There are slight vibration even at higher rpm but it is barely noticeable.
Old Mar 16, 2016 | 09:25 AM
PelicanParts.com
Vendor
Not likely. Are you having idle issues at cold start?
Old Mar 16, 2016 | 09:32 AM
Khai's Avatar
Khai
No issues, just replaced my top passenger side mount and I know bad motor mounts can cause shaking, misfires. Also wasnt sure if idling at 800 as compared to 1k was a big difference, or if it can vary that much from mileage/differene years.
Old Mar 16, 2016 | 09:59 AM
PelicanParts.com
Vendor
So would you say it idles rough when it dips down? I'd probably start with plugs if you haven't had them replaced. MINI recommends an interval of 100,000 miles (161,000 km). I typically change mine every 30-40k miles. If nothing changes then I'd check for intake leaks and then maybe check your fuel filter.
joelmz
Jan 12, 2017 09:48 PM
ultrahuck
Mar 3, 2016 05:37 AM
Feb 22, 2016 02:54 PM
Melissa@Ferneys
MINI5280
Feb 16, 2016 11:49 AM
Feb 16, 2016 08:26 AM
