Engine Rattle 1st Gen R53
Old Mar 13, 2016 | 12:43 PM
jmedford's Avatar
jmedford
I got a 05 cooper s. It had a rattle so i changed timing chain,ten,and guides but it still rattles. Need help thanks
Old Mar 13, 2016 | 09:21 PM
Red96TransAm's Avatar
Red96TransAm
It could be the belt tensioner. When they start to go, they get pretty rattle-y, too.
Old Mar 14, 2016 | 06:59 AM
nkfry's Avatar
nkfry
Did you "pop" the tensioner before starting the car? You will have a "death rattle" if the tensioner hasn't popped yet.
Phone:586-792-6464
Info@DetroitTuned.com
Nick@DetroitTuned.com
Old Mar 14, 2016 | 07:01 AM
jamez's Avatar
jamez
Can you describe the process needed to "pop" it?
Old Mar 14, 2016 | 07:27 AM
nkfry's Avatar
nkfry
We usually leave the valve cover off until the timing cassette and cover are totally finished, but you will go in from the top with a pry bar and find a fulcrum point and pry against the chain setting on the tensioner, it doesn't take much to pop the tensioner, so don't try to kill it.
You'll be able to see more of the tensioner exposed when it pops and the chain won't have slack in it anymore.
Phone:586-792-6464
Old Mar 14, 2016 | 07:42 AM
jamez's Avatar
jamez
Thanks!
How about if you're just installing a new tensioner, and not replacing the rest of the system? Will the new tensioner just pop as normal once the oil pressure is correct? Or does it have to be installed & set up correctly first?
Old Mar 14, 2016 | 08:22 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
Can you possibly distinguish where it's coming from in the engine bay? I'd maybe check the belt tensioner, as said above.
https://www.northamericanmotoring.co...-question.html
888.280.7799 | 6am - 5pm PST
soccerbummer1104
Jul 15, 2024 08:11 AM
Tires, Wheels & Brakes
Jun 3, 2016 06:41 PM
charlie.h
11
Mar 17, 2016 05:43 AM
jmedford
Mar 14, 2016 07:01 AM
Feb 22, 2016 02:14 PM
